Dabar yra 05 Bal 2026 21:12
Naujos temos kūrimas Atsakyti į temą  [ 261 pranešimai(ų) ]  Eiti į Ankstesnis  1 ... 10, 11, 12, 13, 14, 15, 16 ... 18  Kitas
 Pranešimo tema: Re: Ecilop hex vs. Ecilop(ish) H6 vs. China Ecilop(ish) quad
StandartinėParašytas: 22 Sau 2013 21:18
StandartinėParašytas: 22 Sau 2013 21:28
StandartinėParašytas: 22 Sau 2013 21:34
Tai jau parasiau liutukui pm'a.
Bet kad man ir taip atrodo, jog viskas paruosta. Ten reikejo paukstuka uzdet ant fail safe rth,ka as ir padares.
StandartinėParašytas: 22 Sau 2013 21:35
Nu tvarkoj tada, as pasiruosiu virvute, kita karta galesim isbandyti :?
StandartinėParašytas: 22 Sau 2013 22:39
Tai kaip is esmes ir aisku, kad vistik jam pabego nes nepazymejo ka daryt isijungus fail safe. Jam suveike paskutiniai duomenys is Spektrumo. Kai atktivuoji fail safe, turetu naza perimti kontrole ir grazinti i taska is kurio pakilo.
Del viso pikto virvute bus galima prikabinti :)
Siek tiek is meniu, kad maziau abejotumem ;)
If your transmitter supports Fail-Safe, then move the slider to the range which reads Fail-Safe Mode to turn
the area blue, set Fail-Safe output of receiver to input port-U. If you switch off your transmitter now, the U
channel slide should move to Fail-Safe and turn the corresponding area to blue. Otherwise please reset the
fail-safe. MC has built-in auto level Fail-Safe function. That means when the communication between MC and
transmitter is disconnected, the outputs of all command sticks from MC will go to center point. If your
transmitter has only 4 channels, then MC will work in Atti. Mode by default without Fail-Safe function.
Tips:
Please refer to your RC manual for the details of fail-safe setup.
With GPS, it is Enhanced Fail-Safe; without GPS, it is Auto Level Fail-Safe, and the aircraft will land.
Tai dar karta pracekinsiu prie kompo, ka daro naza isjungus radija ir bus galima testuot lauke ;)
ps: per kompa pratestavus dx6i su naza, tai isjungus radija jis uzfiksuoja paskutinius radijos svirteliu padetis. Jei dariau posuki, tai ir lieka posukyje. Bet i kompa ijungus gali visai kitaip reaguot. isbandysiu realybej nepaleidziant is ranku.
StandartinėParašytas: 22 Sau 2013 23:14
Teoriskai jei isjungus radija slideris nueina i Failsafe zona, tai vadinasi Naza pereme valdyma ir neturetu buti svarbu kur yra svirteles... cia reiktu manuale ziuret.
Bet pas mane yra kitaip :wait
Nepamenu,bet kazkodel turejau nustatyt gazo padeti,kad kai isjungiu radija, gazas nukristu i tam tikra padeti... kazkas ten tokio buvo.. o gal ir visiems kanalams butinas failsafe.. :?
Lyg buvo rasyta manuale.. O pas mane FrSky, tai ten kazkas buvo,kad isjungus gazas ar tai pasilieka kaip buves, ar tai nukrenta, nepamenu, bet Failsafe neisijungdavo, todel nustaciau gaza kur noriu ir uzseivinau tai kaip failsafe. Dabar isjungus radija viskas gryzta i nuline padeti (nes taip nustayta failsafe frsky),o gazas nukrenta i ~30%.
Jei failsafe ijungiu su svirtele,neisjungdamas radijos,tai judinant svirteles juda ir slideriai nazos gui.
P.S. o tai liutukas nebuvo nieko pazymejes isvis??? nei Land ,nei Go HOME and land???
Paskutinį kartą redagavo [RS] 23 Sau 2013 00:24. Iš viso redaguota 1 kartą.
StandartinėParašytas: 22 Sau 2013 23:41
StandartinėParašytas: 23 Sau 2013 00:30
O tu siaip kokia radija naudojei? Su Spectrumais tai ten biski paliava yra:)
Pvz Dx6 su savo kaikuriais imtuvais failsafe'o nenustatysi.
Nu kaip, ten galima priburti,miksuojant kanalus ar kazkaip,bet esme,kad pvz ar6200 imtuvas ir kazkurie kiti, failsafe'ina tik gazo kanalo,o Nazai to gali neuztekti.
Kazkaur visai netycia buvau uztikes,kad zmogelis turedamas DX6 , dejo FrskY moduli,kad galetu su Naza naudot,bet kazkaip kai man nebeaktualu ,tai nekreipiau demesio.
Bet reikals yra toks,kad tik pvz Dx8 ir su ja einancius 8 ir gal 7 kanalu imtuvus galima nustatyt Failsafe visiem kanalam.
Esu mates,kad kazkas nusistate failsafe ir DX6 kazkokiu tai butu, bet jis veikia tik esant ijungtai radijai.
Jei radija isjungi failsafe neveikia..
StandartinėParašytas: 23 Sau 2013 01:13
StandartinėParašytas: 23 Sau 2013 01:27
Nei OrangeRX, nei AR6200 neturi normalaus failsafe. AR7000 kaip minimum reikia naudot, norint turėt padorų failsafe. O šiuo atveju - bus kaip ir sakyta, liks paskutinės pozicijos, kurios gautos iš siųstuvo. Taigi, jei tavo kontroleryje nustatyta, kad FS aktyvuojasi su kokiu AUX - kopteris labai sėkmingai nuskris pagal paskutinę gautą komandą..
StandartinėParašytas: 23 Sau 2013 01:30
Nu tai jo,panasu,kad tol veikia,kol radija ijungta.
Tiesa koki imtuva naudoji?
Kiek randu, tai:
"Contrary to what he said, the AR6210 rx will only change the throttle channel during fail-safe. You will have to get a AR7xxx or higher to have true fail safe."
"If your using the DX6i and AR6210 then you can only use RTH when the remote is on.. but if you use a DX8 you can use RTH functions with the Rempote turned off. DX6i works but not when your remote is turned off! Witch is good! lol... But i never run our of batterys. So it never turns off on me.. So the Dx6i works fine with mine!"
Pagal tai iseitu,kad su kaikuriais Spectrum imtuvais dingus rysiui rooookai!
StandartinėParašytas: 23 Sau 2013 03:29
Musu su Liutu planas tai patikrinti yra toks- jis skrenda toliau, o as su prirista virvute prie kopterio einu is paskos, tada toliau nuskridus jis isjungia radija, o as laikydamas ta virvute einu atgal i "home". Jei failsafe nesuveikia, tai uz tos virvutes partraukiu kopteri zemyn, kad nenuskristu i dausas kaip Liutukui. Pasirode tarp kolegu kaip du lapuxai su high-tech aitvaru griztam atgal prie kompo nustatineti failsafe...
StandartinėParašytas: 23 Sau 2013 04:20
Video bus? :woww Turėtų būt geras vaizdelis :)
StandartinėParašytas: 23 Sau 2013 08:49
Na paskaicius RS aisku viena, kad radija butinai reiks keist.
Per brangi rizika butu prarast kopteri.
StandartinėParašytas: 23 Sau 2013 11:16
