Dabar yra 30 Kov 2026 12:15
Naujos temos kūrimas Atsakyti į temą  [ 188 pranešimai(ų) ]  Eiti į 1, 2, 3, 4, 5 ... 13  Kitas
 Pranešimo tema: tricopterio surinkimas,o dabar ir H quodas :)
StandartinėParašytas: 28 Spa 2012 19:21
Pranešimai: 1497
Miestas: panevezys
sveiki gal kas gali padeti sukomplektuoti pagal sita video kas per iranga sudeta i sita trikopteri,nes man su anglu sunkoka biski :) kokie varikliai tai spejau izvelgti,bet ka jis ten apie pagrindus sneka neikertu :D
kiek zinau varikliai 2830-8 1300KV Outrunner Brushless Motor
esc 30A
BATERIJA 3S 2200 mah
serva 13gr, metaliniais dantrc.
Paskutinį kartą redagavo arnestas 16 Kov 2013 14:42. Iš viso redaguota 1 kartą.
 Pranešimo tema: Re: padekit sukomplektuoti
StandartinėParašytas: 28 Spa 2012 19:51
Motors - 2830-8 1300KV Outrunner Brushless Motor Free Mounts
http://www.rctimer.com/index.php?gOo=go ... d=120&pr...
Speed controller - hobby king Hobbyking SS Series 18-20A ESC (card programmable)
http://www.hobbyking.com/hobbyking/stor ... oduct=6548
Or a little better controller is the Exceed RC Proton 30A Brushless ESC Speed Controller at hobby partz
http://www.hobbypartz.com/proton30aair.html
or plush 30 amp at hobbyking
http://www.hobbyking.com/hobbyking/stor ... oduct=2164
Controller at hobbyking HobbyKing Multi-Rotor Control Board V2.1 (Atmega168PA)
http://www.hobbyking.com/hobbyking/stor ... or_Contr...
or the new KKv2 board no need for a programmer or computer.
http://www.hobbyking.com/hobbyking/stor ... ti_rotor...
Programmer at hobby king USBasp AVR Programming Device for ATMEL processors
http://www.hobbyking.com/hobbyking/stor ... ing_Devi...
10CM Male to Male Servo Lead (JR) 26AWG (10pcs/set)
http://www.hobbyking.com/hobbyking/stor ... ervo_Lea...
I use 14 gauge wires
http://www.hobbyking.com/hobbyking/stor ... oduct=9678 red
http://www.hobbyking.com/hobbyking/stor ... oduct=9679 black
1/2 inch wood from home depot or Lowes found in the trim area
1/8 inch ply from craft store or hobby shop
4-40x 1 screws blind nuts and washers from Trimcraft Aviation
http://www.trimcraftaviationrc.com/inde ... fo&cPath... screw
http://www.trimcraftaviationrc.com/inde ... fo&cPath... washers
ir tau cia info truksta? :)
StandartinėParašytas: 28 Spa 2012 20:40
Pranešimai: 1497
Miestas: panevezys
stai ka reiske daugiau praleisti laiko prie kompo o ne garaze :D labai dekingas tau.
kaip supratau reike situ
3vnt sito http://www.rctimer.com/index.php?gOo=go ... id=120&pr..
3vnt sito http://www.hobbyking.com/hobbyking/stor ... oduct=6548
1 vnt sito http://www.hobbyking.com/hobbyking/stor ... lti_rotor..
1 vnt sito komplektuko http://www.hobbyking.com/hobbyking/stor ... Servo_Lea..
baterija 3s2200 mah
ir sitiems varikliams propeleriu gws 10 vnt
ir tris propelerio laikikliu
ir servas
StandartinėParašytas: 28 Spa 2012 21:17
Jo :)
StandartinėParašytas: 28 Spa 2012 21:27
Pranešimai: 1497
Miestas: panevezys
na darkarteli dekui uzsakinejam ir laukiam :)
StandartinėParašytas: 30 Spa 2012 20:21
Pranešimai: 1497
Miestas: panevezys
Na ka pirkciau tricoprerio rema jog butu vieta kamerai ir kad butu kuo lengvesnis ir pagal motoru traukadomina visi iskirus medinius.del kainos sutarsim
Laukiu pasiulimu.
StandartinėParašytas: 01 Lap 2012 00:07
Pranešimai: 1497
Miestas: panevezys
ar tiktu sitas kebulas maniskiai irangai pagal svoti ir ismatavimus ?
StandartinėParašytas: 04 Lap 2012 14:45
Pranešimai: 1497
Miestas: panevezys
kur galima butu gauti tos lengvos medziagos panasios i carbona? ir ar buna kokie nors tricopterio breziniai jog atsispaudinus juos ir poto su lomziku issipjaustiti
cia radau propeleri,bet manau vieno lapo 10cmx30 neuzteks
StandartinėParašytas: 04 Lap 2012 17:13
Pranešimai: 699
Stiklo tekstolita gali naudoti. Paskaityk tema apie multicopterius, ten rasi ir breziniu ir is kokiu medziagu gamintis ir t.t.
Sakura XI Sport
Ansmann Are-2
Traxxas Slash
HK 450v2
Karolis :)
StandartinėParašytas: 04 Lap 2012 17:56
Pranešimai: 1497
Miestas: panevezys
StandartinėParašytas: 04 Lap 2012 19:28
Nėra tokios medžiagos kopteriams, kuri nesilenktų arba nelūžtų. Svorio centrą užtenka padaryt geometriškai tarp variklių, nors realiai kontroleriams šiais laikais yra dzin, gali kompensuot netgi skirtingų propų sudėjimus.
StandartinėParašytas: 07 Lap 2012 21:41
Pranešimai: 1497
Miestas: panevezys
na siandien nusipirkau medienos ir fanieros kaip pirma kopteri tai bandisiu medinuka.taigi ar kojoms uztenka 15mm x 8mm. ar geriau deti 15x15mm.kojas ilgumo ispjoviau 35 cm.koks turi buti svoris proto ribose sitiems motorams? (tuscio kopterio)
StandartinėParašytas: 08 Lap 2012 11:24
Šitiems tai čia kokiems?
StandartinėParašytas: 08 Lap 2012 11:31
na jei kaip sakant
kameros laikiklio standartiskai ner ale mokymus laikys ;)
StandartinėParašytas: 08 Lap 2012 20:30
Pranešimai: 1497
Miestas: panevezys
