Dabar yra 28 Bal 2026 11:01
Naujos temos kūrimas Atsakyti į temą  [ 43 pranešimai(ų) ]  Eiti į 1, 2, 3  Kitas
 Pranešimo tema: Team associated SC10 4x4 Team factory surinkinejimas
StandartinėParašytas: 05 Rgs 2012 21:30
Užsiregistravo: 23 Kov 2011 12:38
Pranešimai: 293
Nusprendziau pradeti ruostis kitam vasaros sezonui, gal net pavyks sudalyvauti ziemos sezone. Kadangi seniai buvau nusprendes keliauti i SC klase, reikejo tik pasirinkti kokiu modeliu vaziuosiu. Ir nusprendziau pasirinkti AE SC10 4x4 FT. O cia nuotraukytes kaip man sekesi ji surinkineti:
Unboxing
Serva
Bag A
Bag B
Po pirmo vakaro surinkta:
Bag C
Bag D
Bag E
Bag F
Bag G
Bag H
Bag HH
Kadangi antra diena padirbejau ilgiau, todel turime i ka paziureti
Bag I
Bag J
Stai po trecio prisedimo vaziuokle beveik surinkta nors dezeje dar kruva maiseliu :)
 Pranešimo tema: Re: Team associated SC10 4x4 Team factory surinkinejimas
StandartinėParašytas: 05 Rgs 2012 21:40
Pranešimai: 258
Ir aš pasidalinsiu sukaupta informacija ką reikia daryti, kad ae važiuotų, o ne kalakutintų... :)
Center diff from RCshox: ()
Review of V1 (). The V2 is now out and is adjusrtable. 4 pins is a good starting point for outdoor. 6 for indoor. More pins is like going up in center diff oil. More info here:
Anything else from rcshox (): Their pistons are great, the garodisks work awesome and the ackbar removes some aggressiveness out of the steering.
Exotek chassis ():
Improves cog, weight and flex.
Exotek Slipper ():
Improves acceleration and cornering however at the expense of a on power push.
Chassis brace:
Available from many retailers, fixes chassis flex which improves handling.
Also easy to make your own.
Sway bars:
Most needed upgrade!
Saddle pack mod:
Improves weight balance and handling.
Springs:
We have now started running front springs on the rear shocks. This stiffens up the rear and considerably improves jumping ability.
Blue/Fwhite and Yellow/FBlue
8mm mod:
Just going to say I know nothing about what it does except it made me faster. Read on rctech about it, please don't ask me as I am not qualified to answer.
Uses the B4.1 carbon hub extenders and 12mm ballstuds with 7mm of spacers. Raises the whole rear link 8mm.
Now for mods and how tos:
Differential removal guide:
While you have your diff out now would be a good time to shim it. Just put and extra stock shim under each sun gear (the big ones on the outdrives).
Fit castle 1415:
58t Spur / 22t Pinion: This gearing allows this 1415 motor which is designed for 3S and 4S to be ran on a 2S happily. There are other spurs from a RC10GT that are smaller that can help with gearing on this Motor. (thanks T-bird)
These red areas do not allow the Big motor to sit flat.
I'm sorry for the bad Dremeling. I did this the night I got the Truck so long ago (7 months?) and haven't bought a new chassis to do this grind cleanly.
And there you have it. 1415 Absurd power on 2S I keep up with Losi Mamba Monsters and run ice cold. I 'adore' this motor. It's so hard to even think about getting another sensored upgrade motor.
Fix the wobbly outdrives:
I think I may have found a way to fix wobbly diffs. You cut down where the 10x16x4 bearing rides to about 1.25mm tall, then you can place a 5x10x3 bearing(AE91156) inside the other bearing for the outdrives to ride in.
FT Mods:
Factory Team Parts now included in the FT Sc10 4x4
~ Yes, You can run Saddle or Stick pack by removing the Saddle Cradle on the FT Sc10 4x4.
~The saddle cradle also has several locations to add ballast weights into your Sc10 to mimic the performance gain of an Exotek Chassis.
FT Shocks Front and Rear
FT Steering Rack (1 additional adjustment hole)
FT TiN Ballstuds in 50% of locations
FT Lightweight Diff outdrives
FT Lightweight Idler gear Shafts
FT Lightweight Top Shafts Front and Rear
FT Alum screws in Upper areas
FT AL M4 Locknuts
FT AL Wheel Hexes
FT AL CVA pin retainers
FT TiN Hinge Pins
FT Sway Bars Front and Rear
FT Chassis Brace
FT VTS Slipper
- Slipper Housing: 91176
- VTS Slipper pad x2: 91177
- VTS Slipper Plate: 91178
- VTS Outer Slipper hub: 91179
FT Saddle Pack Cradle
- Battery Cradle, Lock and Bushing: 91185
- Saddle Pack Strap: 91187And yes pretty much every thing is quoted from CoyoteSlash () on Rctech
Now the Achilles heal of the truck:
Some may notice the truck does not preform as well as the competitors on outdoor tracks. While the gap is narrowing due to the V2 diff and other mods it is still there. Some people believe it is because the truck is to light, this is a common misconception. It s because of the weight distribution of the truck. The Losi, Durango and most 1/8 buggys have a very close to 50/50 F/R distribution. the SC10 4x4 has about 42/58 stock and 45/55 with saddles. This gives it a definitive edge on tight high traction indoor tracks for where this truck was designed. However the truck needs more weight up front to tackle the outdoor tracks. the only way this can be accomplished is to add weigths as none of the electronics can be moved. However this leads to a barbell effect as now the truck does not rotate as well. More experimentation is necessary to see if a 50/50 weight distribution is possible while keeping the rotation of the truck.
Vaidas
TLR 8ight-E 4.0
Paskutinį kartą redagavo Noxius 06 Rgs 2012 00:44. Iš viso redaguota 4 kartus.
StandartinėParašytas: 05 Rgs 2012 21:51
Slashui ir tam maziau reikia chimycint viska....
StandartinėParašytas: 06 Rgs 2012 13:10
Pranešimai: 1733
Plasmasiniai difai :DDD
HB D812
HB D8
HB D8e
HB D413
Kyosho Lazer FS2 SP
HPI CRAWLER
StandartinėParašytas: 06 Rgs 2012 14:30
Pranešimai: 366
Kyosho MP9 TKI3
PowerHD DC-1217MG
Sanwa M11x
HPI Sprint 2
Eco mini expert laivelis
Tel.+37064035557
StandartinėParašytas: 07 Rgs 2012 22:44
Pranešimai: 293
Bag K
Bag L
Bag M
Bag N
Bag LL
Stai vaziuokle surinkta, laukia ratu sistemos ir kito:
Greitu laiku bus dar nuotrauku :)
StandartinėParašytas: 09 Rgs 2012 21:19
Pranešimai: 293
Atsidariau paskutini maiseli:
Bag O
Varikliuka idejau Tekin 4600kV
Surinkta sistemele, isbandyta tik liko laidai prasivedzioti
Modeliukas surinktas ir paruostas. kebula daziau pirma karta bet gavosi visai neblogai
Nuotraukoje nera tikra spalva, dienos sviesoje ryskesne :)
StandartinėParašytas: 10 Rgs 2012 18:45
Pranešimai: 1733
Uzskaitau :)
HB D812
HB D8
HB D8e
HB D413
Kyosho Lazer FS2 SP
HPI CRAWLER
StandartinėParašytas: 10 Rgs 2012 20:25
Pranešimai: 936
Skype: robis-ut-lt
+37061011450
²º15
StandartinėParašytas: 11 Rgs 2012 21:00
Pranešimai: 293
Siandien pavazinejau su modeliuku. Po sio pasivazinejimo likau patenkintas savo pirkiniu. Aisku, reikia mokytis vairuoti ir sokineti. Dar manau teks pazaisti su amortiku tepaliukais, nusprendziau, kad galas siek tiek per kietas. Greitu laiku bus filmukas kaip sekesi vazineti :)
StandartinėParašytas: 11 Rgs 2012 21:13
Pranešimai: 293
Filmkas:
Bus daugiau video :)
StandartinėParašytas: 11 Rgs 2012 21:30
Užsiregistravo: 27 Lap 2009 10:29
Pranešimai: 222
Miestas: Jonava
Ir kiek už viską sumokejai pilnai? :)
LOSI SCTE
StandartinėParašytas: 11 Rgs 2012 21:39
Pranešimai: 1306
StandartinėParašytas: 11 Rgs 2012 21:50
Pranešimai: 594
Pranešimai: 258
Atidaužytas Tadžius gerai šiandien :D
Vaidas
TLR 8ight-E 4.0
