Dabar yra 28 Kov 2026 08:54
 Pranešimo tema: Checking the direction of the transmitter channels problemos
StandartinėParašytas: 04 Bal 2012 19:17
Pranešimai: 113
nezinojau kaip tema tiksliau uzvadinti.. bandysiu nupasakot kas darosi
turiu quadcopteri, kuri bandau sureguliuot pagal: http://rcexplorer.se/Educational/kkguid ... quadx.html
valdymas paprastas: http://www.propeleris.lt/rc_valdymas/st ... param=wfly
susijungiau viska kaip ir pagal ta
On a Futaba/Hitec receiver they plug in as follows:
Aileron - Channel 1
Elevator - Channel 2
Throttle - Channel 3
Rudder - Channel 4
lygiai taip pat man gavosi.
toliau pasidariau motorus kad suktusi visi i reikiamas puses.. susikalibravau esc, startuoja viskas kartu normaliai
toliau... 3. Checking the direction of the transmitter channels
- Move the Pitch (Elevator) stick on the transmitter forward. The two back motors (M3,4) should speed up. If it doesn’t, reverse the channel in your transmitter.
mano atveju gaunasi sitaip, kai as pastumiu elevator kanalo svirti i prieki, greiteja visi 4 motorai, pastumus svirti atgal, visi trys motorai apart M4 leteja, o M4 motoras sukasi kaip sukesis, nei leteja nei greiteja. (panasu i quado + konfiguracija)
- Move the Roll (Aileron) stick to the left. The two right motors (M2,3) should speed. If it doesn’t, reverse the channel in your transmitter.
mano atveju gaunasi sitaip, kai as pastumiu aileronu svirti i kaire, tada greiteja M1 ir M2, pastumus i desine - greiteja M3 ir M4 motorai (cia atrodytu kaip butu elevator kanalas, kazkas panasaus... )
- Move the Yaw (Rudder) stick to the left. Motor M1 and M3 should speed up. If it doesn’t, reverse the channel in your transmitter.
mano atveju gaunasi sitaip, kai as pastumiu ruderio svirti i kaire, tada trys motorai (M2,3,4) leteja, o M1 nei greiteja nei leteja, sukasi kaip sukesis, pastumus svirti i desine visi motorai nei leteja nei greiteja.(isvis nesuprantu kas cia darosi...)
kame cia reples? blogai sujungti laidai galetu buti? ta prasme motorai sumaisyti paciame borde? nes jungiau taip:
http://imageshack.us/photo/my-images/835/kkkkvw.jpg/
ar softas neisirases? nes atrodytu lyg butu quado+ konfiguracija ;/
softa esu perrasinejas kelis kartus, pries tai turejau tricopteri, tai reikejo persirasyti.
siuo atveju perrasant softa jokiu erroru, viskas tvarkoje.
radija kaip jau minejau paprasta, jokiu mixu, trimeriai nustatyti ties viduriu, isskyrus gazo, nes neuzsiarmina bordas.
mano pirmasis quadcopteris, todel tamsus miskas cia :) informacijos internete daug, atrodytu nieko sudetingo ji pasidaryt ir priverst skristi, bet man siuo konkreciu atveju nezinau kas ne taip :)
komplektacija:
http://www.hobbyking.com/hobbyking/stor ... duct=12921
http://www.hobbyking.com/hobbyking/stor ... duct=19534
http://www.hobbyking.com/hobbyking/stor ... duct=10279
http://www.goodluckbuy.com/30a-brushles ... -pack.html
prasau pagalbos, nes pavasaris ant nosies, norisi skraidyti :) o dar hobbykingas surenge toki smagu konkursa :)) tikiuosi viska cia aiskiai paaiskinau... jeigu neaisku, klauskit :)
 Pranešimo tema: Re: Checking the direction of the transmitter channels probl
StandartinėParašytas: 04 Bal 2012 19:30
Panašu kad sumaišyti input kanalai (jei jau greitėja visi keturi, nestumant throttle).
Čia yra išvardinti kanalai:
Ar iš imtuvo einantys kanalai sujungti būtent taip? Siūlau atjungti plokštę, pajungti po ESC (ar servo) į imtuvo kanalą ir susitikrinti, ar tikrai ta sticko funkcija atitinka imtuvo outputą.
EDIT: fix'd nuoroda, kažkoks nupušęs URL parseris šituose forumuose
Paskutinį kartą redagavo ABL 04 Bal 2012 19:39. Iš viso redaguota 1 kartą.
StandartinėParašytas: 04 Bal 2012 19:32
Pranešimai: 113
StandartinėParašytas: 05 Bal 2012 15:20
Pasirikrink dar, ar teisingai sujunges motorus. As neseniai is HK pasiemiau V3 board'a, tai motoru numeriai ten visiskai kitokie, nei pas standartinius KK. Vargau neteisingai sujunges :D Ten berods pas tave V2 board'as? Eik i "files" ir ziurek jo manuala, gal ten irgi kitaip motorai jungiasi, tokiu atveju per rcexplorer busi ne taip sujunges...
StandartinėParašytas: 05 Bal 2012 15:46
Jo, panasu, kad ir tas board'as kitaip motorus numeruoja... Kaip esi perflashines, tai daba nezinau, kaip jungti :?
