Naudota JR G770T gyro - 170lt
jr_g770t_cx.jpg [ 114.39 KiB | Peržiūrėta 3213 kartus(ų) ]
* Constant Pirouette rate
* Both Heading-Lock and Normal modes
* Aluminum Gyro case
* Analog or Digital servo compatibility
JR G770T heading Hold Gyro - This small gyro is metal cased to reduce the possibility of interference from speed controllers or motors in electric models, though it is equally suitable for use in IC powered machines.
Size mm: 20x27x25.5
Weight: 30g
Type: SRVS UltraLok n?Technology 3D Gyro
Weight: 30 gram
Dimensions (WxLxH): 1.12"x.83"x.35"
Gain Type: Heading lock and normal rate modes interlocked with Gyro Gain
Operating Voltage: 4.8 to 6.0 V (Note: Most tail servos are limited to 4.8V)
Reversing Switch: Yes
High/Low Frame Rate Select: Yes
Servo Travel Limiter: Yes
Current Draw: 80 mA
Naudotas Gaui Gu-365 flybarless sistema -120lt
veikia puikiai jei modelis neturi problemu su vibracijomis.
gu-365.jpg [ 36.2 KiB | Peržiūrėta 2366 kartus(ų) ]
The FES 3 Axis gyro is very easy to setup and eliminates the need for a tail gyro.
GU-365 3 Axis GYRO Specifications :
-Control system : AHDCS (Active Helicopter Digital Control System)
-Content : 3-Axis gyro
-Operating voltage : 4 ~ 6V DC
-Dimensions : 44.5 x 31 x 14mm
-Weight: 18g
Naudotas Neu Motor 1910/1Y - 190lt
Puikus 8s lektuvinis variklis. Gali buti naudojamas heliams(trex600) bagiams ir t.t.
kv 1050 rpm
max 33V
284g
Pastoviai 1200W max 2400W
http://www.neumotors.com/Site/1900_series.html-----------------------------------------------------------------------
Klaipeda
+37067642010
