Dabar yra 22 Bir 2025 04:47
 Pranešimo tema: DX6i recall (atsaukimas del broko)
StandartinėParašytas: 07 Bal 2009 07:28
Užsiregistravo: 15 Kov 2008 13:27
Pranešimai: 333
Miestas: Trakai - Vilnius
Starting back on Jan 30th of this year Horizon/Spektrum released a service bulletin warning some DX6i radios could have potentially bad stick potentiometers. They described a process to inspect the radio yourself and see if service was needed.
Well now there have been two confirmed injuries due to the DX6i transmitter malfunctioning, so Horizon/Spektrum has initiated a full product recall for certain date codes. The date codes cover some 15,000 units of the DX6i.
To find out if your DX6i needs to be sent in as part of the recall. Open up the battery door, remove the batteries and find the date code. If no date code is present, then you are in the clear and no need to send in your transmitter.
If you have one of the following codes please contact Horizon/Spektrum and send in your radio ASAP.
807E
808E
809E
810E
811E
812E
901E
Sources:
Official Spektrum consumer recall notice
Official news release from the U.S. Consumer Product Safety Commission
http://www.rcheliresource.com/horizon-r ... nsmitters/
Marius
JR 11X 2.4Ghz
Trex 700DFC Pro / Trex 700 DFC Night / Logo 500 / ZMR250 / SAVAGE HP XL
 Pranešimo tema: Re: DX6i recall (atsaukimas del broko)
StandartinėParašytas: 07 Sau 2011 12:07
Pranešimai: 224
Iskeliu viena tema/ problema, nes susiduriau su ja. Ar kam teko susidurti su sita problema ir grazinti aparata ar gal labiau patyre bandete kazkaip remontuoti ? As pirkau saviski i ranku naudota ir pabandyti galejau tik tada kai po ilgesnio laiko tarpo isigijau imtuveli. Ilgainiui ishlindo ir problemos.. Siuo metu pavyko specialiom preimonem ishvalyti ir sutepti petenciometrus, kazkiek laikys. Idomu kokie sansai susisiekti del serviso ir detaliu? Kiek zinau gamintojas tiesiogiai su vartotoju nedirba. Reikia atstovu ar prasyti kazko kitoj didesnej valstybej pvz UK pagalbos kad susisiektu .. Gal kas gali padeti ?
StandartinėParašytas: 18 Sau 2011 15:52
Pranešimai: 224
Tai niekam is DX6i turetoju neteko susidurti su tokiom problemom ?
StandartinėParašytas: 18 Sau 2011 21:51
Man yra tekę turėt problemų su elevatoriaus potenciometru, pultas ne iš recall serijos, naujesnis gerokai. Sprendžiau savarankiškai, identiški potenciometrai sudėti Turnigy MG930 servose. Tai teko pasikeist pačiam. Neturiu kada siuntinėt, o pigiau pačiam pasikeist.
StandartinėParašytas: 20 Sau 2011 21:30
Pranešimai: 224
Dekui eil ! Labai naudinga info. Aisku tos servo nepigios, bet geriau jau servos po 14$ vietoj naujo siustuvo :) Dar kritishka nera. As lupau tuos potencus ardziau juos ir valiau. Buvo beda su visais kanalais, bet gazo ir uodegos kanalai pastebimai trukciojo.. Dabar viskas veikia, bet nepaslaptis, kad laikina.. Tie potencai specifiniai, netandartiniai. Panasu kad gaminami sitai siaurai sriciai. Analogu nepavyksta rasti nei pas viena elektronikos tiekeja nei LT nei uzsieny kiek ieskojau. Beto juos sunku specifikuoti, nes nera aiskaus tipo numerio ar dar kazkokiu indentifikaciniu zymenu..
StandartinėParašytas: 20 Sau 2011 22:01
Jei neklystu, ant jų tik užrašyta B5K ar kažkas tokio.
StandartinėParašytas: 20 Sau 2011 22:38
Pranešimai: 224
Taip, bet tai tiesiog reiskia, kad jie yra 5K (Kilo Omu).. :) Aisku idomu butu kazkokiais kanalais susisiekti su pagrindiniais tiekejais, gamintojais ir uzklausti del nauju potencu. Idomu kiek uzsipleshtu ? :)
