Dabar yra 01 Rgs 2026 10:41
 Pranešimo tema: Skaitmeninis Kompiuterizuotas Pakrovejas (Naujas)
StandartinėParašytas: 14 Spa 2010 16:28
Užsiregistravo: 30 Geg 2010 07:26
Pranešimai: 48
Miestas: Širvintos
Parduodu Nauja Kompiuterizuota pakroveja HobbyKing ECO6 50W 5A Balancer/Charger w/ accessories
Capable of charging any size Lipoly battery up to 6 cells or at 5A.
The ECO-SIX includes an array of charging plugs and wires to suit almost any application and comes with JST-XH balancing plugs so you can charge and balance your ZIPPY/TURNIGY packs easily.
Input power is 11-18v, perfect for car batteries or pc/laptop powersupply.
Features;
Microprocessor controlled
Delta-peak sensitivity (NiMH/NiCd)
Individual cell balancing
Li-ion, LiPo and LiFe capable
Ni-Cd and NiMH capable
Large range of charge currents
Store function, allows safe storage current
Time limit function
Input voltage monitoring. (Protects car batteries at the field)
Data storage (Store up to 5 packs in memory)
Battery break in and cycling.
Spec.
Input Voltage: 11~18v
Circuit power: Max Charge: 50W / Max Discharge: 5W
Charge Current Range: .1~5.0A
Ni-MH/NiCd cells: 1~15
Li-ion/Poly cells: 1~6
Pb battery voltage: 2~20v
Weight: 170g
Dimensions: 138x75x23mm
Tai vat kas nesupratot tai lietuviskai: Pakrovimas 5A, iskrovimas 1A. Krauna visu tipu Akumuliatorius.
Pridedu ir maitbloki
Viso kaina: 100lt + siuntimo islaidos (~5lt)
RC Drift
Technika: HPI Sprint 2 Drift.
Vardas: Airidas
Amžius: 17 metų
 Pranešimo tema: Re: Skaitmeninis Kompiuterizuotas Pakrovejas (Naujas)
StandartinėParašytas: 14 Spa 2010 17:14
Užsiregistravo: 06 Vas 2010 21:48
Pranešimai: 140
Miestas: Jonava-Kaunas
oj. sorry uz ot
...Da Nuu...
Paskutinį kartą redagavo TyyT 14 Spa 2010 18:21. Iš viso redaguota 1 kartą.
