Dabar yra 01 Rgp 2026 05:14
 Pranešimo tema: Reikia pagalbos del valdymo
StandartinėParašytas: 09 Rgs 2009 18:39
Užsiregistravo: 01 Rgs 2008 13:34
Pranešimai: 57
Sveiki, noriu suzinoti kuris is siu tiks putinuko valdymui, o jei tiks abu kuris geresnis:
info apie ji:
WFT06X-A 2.4GHz 6CH 6 CH transmitter For RC model
Specification:
* Model: FT06X-A
* Use in: airplane, HDE helicopter, fixed-pitch helicopter, car, boat
* Band: 2.400GHz-2.483GHz have MODL1 and MODL2
* Output power: ≤100mW
* Current drain: ≤160mA
* Modulation: PPM
* RF module: Set-in
* Power: 9.6-12V
* Dual rate range: 100%~125%
* Mix: Flaperon (Ch 6 and Ch 1 mix)
* V-tail (Ch 4 and Ch 2 mix)
* Elevon (Ch 1 and Ch 2 mix)
* HDE helicopter (Ch 3 to Ch 4 and Ch 6 mix)
* HDE helicopter (Ch 3 to Ch 6 mix)
* Reverse switch: Ch 1 aileron, Ch 2 elevator, Ch 3 throttle, Ch 4 rudder, Ch 6 Flap/pitch
* Low voltage warning: battery voltage <8.8V, LED glitters and buzzer buzzes once a second;
* battery voltage <8.3V, LED glitters and buzzer buzzes twice a second.
* Charge jack
* Simulator jack
Package:
* 1x 6CH 2.4G Transmitter
* 1x 6CH 2.4G Receiver
* 1x Manual
Ce kitas:
info:
WFT06X-C 2.4GHz 6CH 6 CH transmitter For RC model
Specification:
* Model: FT06X-C
* Use in: CCPM helicopter, airplane, fixed-pitch helicopter, car, boat
* Output power: ≤750mW
* Current drain: ≤300mA
* Modulation: PPM
* RF module: Set-in
* Power: 9.6-12V
* Dual rate range: 100%~70%
* Mix: CCPM helicopter (Ch 3 to Ch 1, Ch 2, Ch 6 mix)
* No mix function in airplane
* CCPM helicopter 3D fly
* CCPM helicopter throttle cut
* CCPM helicopter aileron and elevator mix reverse
* CCPM gyro sensitivity adjustment
* CCPM helicopter pitch and gyro sensitivity data storage
* CCPM helicopter 3D throttle middle curve adjustment
* Charge jack
* Simulator jack
Package:
* 1x Manual
StandartinėParašytas: 09 Rgs 2009 19:43
As manau kad pirmasis. :|
StandartinėParašytas: 09 Rgs 2009 19:58
Pranešimai: 57
O man draugas sake kad abu veiks, tai tiesa kad abu veiks?
StandartinėParašytas: 09 Rgs 2009 21:13
Pranešimai: 540
HPI Baja 5B
StandartinėParašytas: 09 Rgs 2009 21:17
Pranešimai: 57
StandartinėParašytas: 09 Rgs 2009 21:19
StandartinėParašytas: 09 Rgs 2009 21:35
Užsiregistravo: 30 Kov 2008 19:08
Pranešimai: 89
StandartinėParašytas: 10 Rgs 2009 12:11
Pranešimai: 57
StandartinėParašytas: 10 Rgs 2009 12:21
StandartinėParašytas: 10 Rgs 2009 12:24
Pranešimai: 1123
Audrius
StandartinėParašytas: 10 Rgs 2009 12:26
Pranešimai: 57
StandartinėParašytas: 10 Rgs 2009 19:39
Pranešimai: 57
o kiek tas pirmas turetu kainuot?
StandartinėParašytas: 10 Rgs 2009 20:06
Kiek pardavėjas prašo, tiek ir kainuoja. Aišku, nekalbu apie Lietuvos perekupus, kurie perpardavinėja.
