Dabar yra 14 Spa 2026 13:04
 Pranešimo tema: gyro JRG770T GU-365 flybarless ir Neu Motor 1910/1Y
StandartinėParašytas: 25 Sau 2011 15:15
Užsiregistravo: 11 Bir 2005 19:52
Pranešimai: 239
Miestas: Klaipeda
Naudota JR G770T gyro - 170lt
jr_g770t_cx.jpg [ 114.39 KiB | Peržiūrėta 3215 kartus(ų) ]
* Constant Pirouette rate
* Both Heading-Lock and Normal modes
* Aluminum Gyro case
* Analog or Digital servo compatibility
JR G770T heading Hold Gyro - This small gyro is metal cased to reduce the possibility of interference from speed controllers or motors in electric models, though it is equally suitable for use in IC powered machines.
Size mm: 20x27x25.5
Weight: 30g
Type: SRVS UltraLok n?Technology 3D Gyro
Weight: 30 gram
Dimensions (WxLxH): 1.12"x.83"x.35"
Gain Type: Heading lock and normal rate modes interlocked with Gyro Gain
Operating Voltage: 4.8 to 6.0 V (Note: Most tail servos are limited to 4.8V)
Reversing Switch: Yes
High/Low Frame Rate Select: Yes
Servo Travel Limiter: Yes
Current Draw: 80 mA
Naudotas Gaui Gu-365 flybarless sistema -120lt
veikia puikiai jei modelis neturi problemu su vibracijomis.
gu-365.jpg [ 36.2 KiB | Peržiūrėta 2368 kartus(ų) ]
The FES 3 Axis gyro is very easy to setup and eliminates the need for a tail gyro.
GU-365 3 Axis GYRO Specifications :
-Control system : AHDCS (Active Helicopter Digital Control System)
-Content : 3-Axis gyro
-Operating voltage : 4 ~ 6V DC
-Dimensions : 44.5 x 31 x 14mm
-Weight: 18g
Naudotas Neu Motor 1910/1Y - 190lt
Puikus 8s lektuvinis variklis. Gali buti naudojamas heliams(trex600) bagiams ir t.t.
kv 1050 rpm
max 33V
284g
Pastoviai 1200W max 2400W
http://www.neumotors.com/Site/1900_series.html
Klaipeda
+37067642010
DS610x3.jpg [ 17.05 KiB | Peržiūrėta 3215 kartus(ų) ]
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
Paskutinį kartą redagavo adm 01 Lap 2011 20:35. Iš viso redaguota 11 kartus.
 Pranešimo tema: Re: 3 vnt. Align 610 servu - 500lt
StandartinėParašytas: 25 Sau 2011 15:48
Pranešimai: 584
Miestas: ----
čia už vieną, ar už visas kartu?
dingau ;)
StandartinėParašytas: 25 Sau 2011 15:51
Pranešimai: 239
Miestas: Klaipeda
uz visas
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
StandartinėParašytas: 07 Vas 2011 16:00
Pranešimai: 239
Miestas: Klaipeda
475
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
 Pranešimo tema: Re: DS-610 servos gyro gp700 JRG770T GU-365 flybarless NEU19
StandartinėParašytas: 16 Vas 2011 14:26
Pranešimai: 239
Miestas: Klaipeda
biski dadejau turto
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
StandartinėParašytas: 20 Vas 2011 11:56
Pranešimai: 239
Miestas: Klaipeda
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
Paskutinį kartą redagavo adm 01 Lap 2011 20:18. Iš viso redaguota 2 kartus.
StandartinėParašytas: 02 Kov 2011 15:09
Pranešimai: 239
Miestas: Klaipeda
uodegos menteliu aliumininiai laikikliai
tinka T-REX 550E/600/600 Nitro/700 Nitro/700E
kaina 60lt
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
StandartinėParašytas: 08 Bir 2011 15:09
Pranešimai: 239
Miestas: Klaipeda
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
Paskutinį kartą redagavo adm 01 Lap 2011 20:19. Iš viso redaguota 1 kartą.
 Pranešimo tema: Re: -20% DS-610 servos gyro gp700 JRG770T GU-365 flybarless
StandartinėParašytas: 26 Bir 2011 17:33
Užsiregistravo: 21 Bir 2011 23:26
Pranešimai: 108
Labas domina Align servos kokia paskutine kaina su hornais? Ar turi ruder serva DS650? Ar pagal ismatavimus tiks HK600?
StandartinėParašytas: 26 Bir 2011 21:43
Pranešimai: 108
Na servos man per brangios pasieskosiu sau kitu...
Dar turi Gaui Gu-365 flybarless?
Ar gerai laikys HK450?
O HK600 desiu http://www.hobbyking.com/hobbyking/stor ... duct=11733
Kaip manai ar stipriai sie abu skiriasi?
 Pranešimo tema: Re: -20% DS-610 servos gyro JRG770T GU-365 ir 3G flybarless
StandartinėParašytas: 29 Bir 2011 12:59
Pranešimai: 239
Miestas: Klaipeda
Align gyro parduota!
JR G770T gyro tik 175lt
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
Paskutinį kartą redagavo adm 01 Lap 2011 20:22. Iš viso redaguota 1 kartą.
StandartinėParašytas: 29 Bir 2011 14:14
Pranešimai: 239
Miestas: Klaipeda
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
StandartinėParašytas: 07 Lie 2011 09:49
Pranešimai: 239
Miestas: Klaipeda
Gal kam geru servu? :liux
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
StandartinėParašytas: 26 Lie 2011 09:04
Pranešimai: 239
Miestas: Klaipeda
Naujos Trex 450 pro galvos dalys:
Metal Flybar Control Set [H45019]
http://www.fast-lad.co.uk/store/h45019_ ... -6770.html
H45023 Metal Washout Control Arm [H45023]
http://www.fast-lad.co.uk/store/h45023_ ... -6708.html
HS1278 New Metal Washout Base 450 [HS1278]
http://www.fast-lad.co.uk/store/hs1278_ ... -3610.html
Uz viska tik 70lt
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
StandartinėParašytas: 25 Rgs 2011 22:03
Pranešimai: 108
