Dabar yra 13 Vas 2026 08:53
 Pranešimo tema: 35A ESC RCE-BL35X ir 430L Brushless Motor(3550KV) RCM-BL430
StandartinėParašytas: 20 Rgs 2008 15:38
Užsiregistravo: 09 Gru 2006 14:56
Pranešimai: 513
Miestas: Rokiškis
35A Brushless ESC(Governer Mode) RCE-BL35X
*Contimuous current:35Amps with porper air flow
*Surge current:45Amps for 15seconds
*Supporting motor types:2 poles to 10+poles in/outrunner brushless motors
*Supporting maximum RPM:2poles=>190,000rpm
*Supporting input voltage:5.5V~16.8V
*Supporting battery types: Li-ion/ Li-poly 2~4 cells, Ni-Mh 6-12 cells
*BEC output: Max current 2A
2 cells Lithium/6~7 cells Ni-Mh=>4servos
3 cells Lithium/8~9 cells Ni-Mh=>3servos
4 cells Lithium/10~12 cells Ni-Mh=>2servos
*Size:45X23X12m/m
*Weight:25g
Kaina: 120 Lt
*Input voltage: DC7.4~14.8v
*Max continuous current: 35A
*Max output power:350W(prox.)
*KV value:3550KV
*Dimension: spindle 3.16x27.5x39.8mm
*Weight: 70g (prox.)
Kaina: 120 Lt
Kontaktai: PM; Skype: swokas arba tel.: 867054910
StandartinėParašytas: 24 Rgs 2008 19:13
Pranešimai: 513
Miestas: Rokiškis
Perkant komplekta, kaina tik 190 Lt
StandartinėParašytas: 02 Spa 2008 13:36
Pranešimai: 513
Miestas: Rokiškis
Nauja variklio kaina: 79 Lt
