Dabar yra 17 Bir 2026 13:05
 Pranešimo tema: Parduodu savo surinkta drona/arba dalis
StandartinėParašytas: 10 Rgs 2017 19:14
Užsiregistravo: 06 Lie 2016 12:44
Pranešimai: 6
Parduodu droną kurį pats surinkau, tačiau nebeturiu laiko juo užsiimti.
Dronas veikia puikiai, tačiau dar nėra sumontuota vaizdo perdavimo į akinius sistema.
Pridedu naudotų detalių sąrašą:
-5x DYS BE1806 1806 2300KV Brushless Motor 2-3S for Mini Multicopters
-H250 ZMR250 250mm Carbon Fiber Mini Quadcopter Multicopter Frame Kit
-2PCS XT60 Female Plug 12AWG 10cm With Wire
-10 Pairs Kingkong 5045 5x4.5 Inch Bullnose PC Fiberglass Propellers CW CCW Color: Green
-Skyzone Upgrade TS5823S 40CH 5.8G 200MW AV Transmitter Module RP-SMA Female
-FPV 1/3 Sony CCD 800TVL FPV Camera for QAV250 FPV Racer Mode: PAL
-5x DYS XM Seris XM20A BLHeli mini 20A ESC V1 For High KV Power Electronic Speed Controller
-Upgrade NAZE32 F3 Flight Controller Acro 6 DOF/Deluxe 10 DOF for Multirotor Racing Model: Deluxe
-MXK Power Distribution Board PDB with OSD BEC Output 5V 12V 3A LC Filter for CC3C Naze32 F3
-Upgraded FlySky FS-TH9X 2.4G 9CH Transmitter With FS-R9B RM002 Mode 2
-5.8GHz Petals Clover Mushrooms Antenna For FPV System Mode: L Type RP-SMA Male
-260pcs M3 Nylon Black Hex Screw Nut M-F Stand-off Set Assortment Kit Box
-[PARDUOTA] Quanum DIY FPV Goggle Set with Monitor (KIT) (EU Warehouse)
-IMAX B6AC 50W input AC/DC universalus kompiuterizuotas pakrov4jas su dvigubu matinimu
-Turnigy nano-tech 1000mAh 11.1V 3S 25~50C
-[PARDUOTA] Turnigy nano-tech 1300mAh 11.1V 25~35C
-Apsauginis maišelis LiPo akumuliatoriams 25x33cm
-Lantian 2 in 1 WS2812B LED And 5V Active Buzzer For FPV NAZE32 Skyline32 Flight Controller
-Upgrade NAZE32 F3 Flight Controller Acro 6 DOF/Deluxe 10 DOF for Multirotor Racing (Model: Acro)
-MICRO MinimOSD Minim OSD Mini OSD W/ KV Team MOD For Racing F3 Naze32 Flight Controller
-5PCS Banggood 220mm Battery Tie Down Strap for RC Multirotor
-4x EMax MT1804 MT1806 Brushless Motor Prop Cap Nut CW/CCW 1pcs (2xCCW/2xCW)
-Eachine RC832 Boscam FPV 5.8G 32CH Wireless AV Receiver
-FT232RL FTDI USB To TTL Serial Converter Adapter Module For Arduino
Labai norėčiau parduoti viską kartu.
Jei turite klausimų - skambinkite telefonu papasakosiu plačiau.
+37063032461 /// pmelinis[at]gmail.com
Miestas - Kaunas. Galiu ir siūsti.
Siūlykit kainą. Pirkau praeitais metais, skrista gal iki 20 kartų. Viskas veikia, nėra jokių pažeidimų. Dalis detalių kaip atsarginės.
Nuotraukos:
https://i.imgur.com/EgiFciV.jpg
https://i.imgur.com/jtmgN8g.jpg
https://i.imgur.com/PkrGvQm.jpg
https://i.imgur.com/GqdrJ71r.jpg
https://i.imgur.com/MJrEM7Z.jpg
https://i.imgur.com/0Ee14jD.jpg
https://i.imgur.com/ackmQnd.jpg
https://i.imgur.com/rSPyTXg.jpg
 Pranešimo tema: Re: Parduodu savo surinkta drona/arba dalis
StandartinėParašytas: 01 Spa 2017 10:53
Pranešimai: 6
Parduoti:
Vartotojai naršantys šį forumą: Registruotų vartotojų nėra ir 22 svečių
