Dabar yra 13 Bir 2025 20:51
 Pranešimo tema: UBEC
StandartinėParašytas: 24 Vas 2012 21:07
Pranešimai: 260
Kas koki naudojate UBEK? Kuris yra geras is HobbyKing? Neapsisprendžiu koki imti.
Naudosiu "šarkai" 5 servai, 2 gyroskopai, tai manau bus problemų jai nebus UBEC
Paskutinį kartą redagavo gigiliamouse 01 Kov 2012 22:23. Iš viso redaguota 1 kartą.
 Pranešimo tema: Re: UBEC
StandartinėParašytas: 01 Kov 2012 22:22
Pranešimai: 260
Paprasto BEC 3A ant ESC kuris yra integruotas, as manau neuzteks, tai ar galit kas koki pasiulyti is HK?
StandartinėParašytas: 01 Kov 2012 22:25
5A turetu uztekt ;)
StandartinėParašytas: 01 Kov 2012 22:38
Pranešimai: 260
Kaip sitas butu?
TURNIGY 3A UBEC w/ Noise Reduction
Spec.
Output: 5v/3A or 6v/3A (Selectable via jumper)
Noise: <50mVp-p(@2A/12v)
Input: 5.5v-23v (2-5S Lipo pack, 5-15cells NiMh)
Weight: 7.5g
Features.
Over current and over heat protection.
Switching frequency 300khz.
Chip Efficiency is 92%. This UBEC utilises switching technology to gain a much higher efficiency than liniar BEC. Which means less heat and longer battery life.
The UBEC is equiped with a noise reduction alloy housing to reduce noise even further.
Incorrect polarity safety feature ensures the UBEC will not be destroyed should the battery be connected incorrectly.
Not* this is an original UBEC. There is now a cloned version on the market, it is slightly cheaper but reliability may not be as good, find it here:HKUBEC3A
StandartinėParašytas: 01 Kov 2012 22:47
Silpnas gali but, cia tik 3A
StandartinėParašytas: 02 Kov 2012 17:24
Užsiregistravo: 10 Lie 2010 20:36
Pranešimai: 98
Turiu toki UBEC :
Galiu parduoti, susisiek per P.M.
Tokio tavo sarkai per akis uzteks. :)
