Dabar yra 26 Bal 2026 19:13
 Pranešimo tema: gyro JR G770T 350lt, NEU variklis 180lt
StandartinėParašytas: 07 Lap 2009 14:44
Užsiregistravo: 11 Bir 2005 19:52
Pranešimai: 239
Miestas: Klaipeda
Parduodu naudota bet puikiai veikiancia gyro JR G770T.
Kas is Klaipedos, tas yra mates kaip puikiai ji veikia ant mano outrage g5.
Kaina 350lt
tel.867642010
The G770T gyro uses all-new SRVS UltraLok technology to provide constant rotation rates regardless of head speed, wind or flight direction. And with its auto-trimming and anti-drift features, trim fiddling is a thing of the past. What's more, the ultra high response rate G770T holds like no other JR gyro.
Key Features
* Constant Pirouette rate
* Both Heading-Lock and Normal modes
* Aluminum Gyro case
* Analog or Digital servo compatibility
JR G770T heading Hold Gyro - This small gyro is metal cased to reduce the possibility of interference from speed controllers or motors in electric models, though it is equally suitable for use in IC powered machines.
Size mm: 20x27x25.5
Weight: 30g
Type: SRVS UltraLok n?Technology 3D Gyro
Weight: 30 gram
Dimensions (WxLxH): 1.12"x.83"x.35"
Gain Type: Heading lock and normal rate modes interlocked with Gyro Gain
Operating Voltage: 4.8 to 6.0 V (Note: Most tail servos are limited to 4.8V)
Reversing Switch: Yes
High/Low Frame Rate Select: Yes
Servo Travel Limiter: Yes
Current Draw: 80 mA
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
Paskutinį kartą redagavo adm 02 Bal 2010 09:17. Iš viso redaguota 4 kartus.
StandartinėParašytas: 29 Lap 2009 21:18
Pranešimai: 239
Miestas: Klaipeda
gyro 350lt
Neu Motor 1910/1Y - 180lt . Galingas variklis 8s setupui. Sis variklis vienas is geriausiu pasirinkimu trex600 8s setupui. Galima ir ant kitu heliu, lektuvu, bagiu ar pan. puikiai panaudot.
Neturesit bedu su kaitimu, efektingenis uz aligno ar pan variklius, puikiai subalansotas ir t.t.
http://www.neumotors.com/Site/1900_series.html
Pigiau niekur nerasit!!
skype: jonas.sab
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
Paskutinį kartą redagavo adm 02 Bal 2010 09:20. Iš viso redaguota 2 kartus.
StandartinėParašytas: 09 Gru 2009 20:04
Pranešimai: 239
Miestas: Klaipeda
gyro 350lt
variklis 180lt
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
Paskutinį kartą redagavo adm 02 Bal 2010 09:18. Iš viso redaguota 1 kartą.
 Pranešimo tema: Re: gyro JR G770T 350lt, NEU variklis 180lt
StandartinėParašytas: 02 Bal 2010 09:22
Pranešimai: 239
Miestas: Klaipeda
oras atsilo - skraidyt maloniau!
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
