Dabar yra 21 Rgs 2026 17:55
 Pranešimo tema: Visai naujas Quaduose. Reikia pagalbos.
StandartinėParašytas: 12 Sau 2015 20:35
Užsiregistravo: 12 Sau 2015 19:55
Pranešimai: 5
Miestas: Kėdainiai
Sveiki, neseniai belakstydamas youtube'i pastebėjau FPV dronus ir labai susižavėjau, taigi sumaniau pats tokį susikonstruot, bet net nenumanau nuo ko pradėt...
Kadangi nežinau kaip kas apsistojau ties salyginai nebrangiu modeliu:
Reptile 500 MWC X-Mode V3 Alien quadcopter frame.
Wheelbase: 500mm
Min. arm distance: 380mm
Max. arm distance: 480mm
Material: Glass fiber + ABS Plastic
Color: Red & White
Package size: 34.5 * 15 * 5.5cm / 13.6 * 5.9 * 2.2in
Package weight: 478g / 1.05Lbs
A2212 1400KV Brushless Outrunner Motor
KV: 1400
Max Efficiency: 80%
Max Efficiency Current: 4-10A (>75%)
Current Capacity: 12A/60s
No Load Current @ 10V: 0.5A
No. Of Cells: 2-3 Li-Poly
Motor Dimensions: φ27.5 x 30mm
Shaft Diameter: φ3.17mm
Weight: 47g
HOBBYPOWER 30A ESC
Output: Continuous 30A, Burst 40A up to 10 Secs.
Input Voltage: 2-3cells lithium battery or 5-9 cells NiCd/NIMh battery.
BEC: 1A / 5V (Linear mode).
Max Speed: 210,000rpm for 2 Poles BLM, 70,000rpm for 6 poles BLM, 35,000rpm for 12 poles
Baterija 11.1V 5000mAh 50C Max 55C 3S 3Cells RC LiPo Li-Poly
Capacity: 5000mAh
Continuous discharge rate: 50C
Burst rate : 55C
Voltage: 11.1V
Cells : 3
Size: Approximately 155 x 44x 24mm (maybe 0-3mm difference)
Weight: 400g
10x4.5 "1045 CW Propeller QuadCopter APC MWM
Material:Carbon Nylon
Size: 10 x 4.5''
Diameter of Shaft: 6.0mm
Thickness of center: 9.7mm
Recommended wheelbase: 550mm - 700mm
Recommended motor: 800KV - 1100KV
Package size: 30 * 20 * 3cm / 12 * 8 * 1.2 in
Package weight: 55 g / 1.9 oz
Padėkit su Flight controller, Transmitter ir Receiver, Charger.
 Pranešimo tema: Re: Visai naujas Quaduose. Reikia pagalbos.
StandartinėParašytas: 12 Sau 2015 20:47
"Modelis" tai cia jau sukomplektuotas? Tiem motoram per didelis remas, per dideli regai, per didele batareika, per dideli propai. Arba sitam remui per mazi motorai ir biski per didele batareika. Arba sitai batareikai per mazi motorai.
Auksine taisykle (kurios vistiek niekas neklauso:) yra mano parase citata. T.y. geriausias budas pradeti yra nuo jau patikrinto setupo, vietoj to, kad pirkinetis viska is eiles speliojant tiks ar netiks, o po to nusiviliant vel spelioti kodel kopteris per sunkus, nesivaldo, nestabilus ir t.t. :)
StandartinėParašytas: 12 Sau 2015 21:02
Pranešimai: 5
Miestas: Kėdainiai
Tai siūlot mažint bateriją, rėmą regus ir propus ane?
StandartinėParašytas: 12 Sau 2015 21:08
Viska keist :) ir visu pirma uzsiimt pasiskaitymu, http://lag.lt/noobcopter/
StandartinėParašytas: 12 Sau 2015 21:11
Pranešimai: 5
Miestas: Kėdainiai
