Dabar yra 20 Rgs 2026 13:30
Naujos temos kūrimas Atsakyti į temą  [ 261 pranešimai(ų) ]  Eiti į Ankstesnis  1 ... 4, 5, 6, 7, 8, 9, 10 ... 18  Kitas
 Pranešimo tema: Re: Ecilop hexas vs. Ecilop(ish) H6
StandartinėParašytas: 18 Gru 2012 22:48
StandartinėParašytas: 18 Gru 2012 22:59
Nu as praklausiau kazkaip pirma kart ziuredamas:)
Tikekimes pavyks gerai susireguliuoti. Jei su Naza karts nepavyktu,gautum koki atskira kontroleri vien gimbalui kabint
StandartinėParašytas: 18 Gru 2012 23:30
StandartinėParašytas: 18 Gru 2012 23:39
StandartinėParašytas: 19 Gru 2012 00:00
Cia ateiciai:
How to configure gyroscopes on the Ecilop mount:
As gyroscope is responsible only for swinging avoidance, it can be adjusted without flying controller by giving signal directly from receiver.
Adjustable parameters of gyroscope:
If gyroscope is not weakening but straightening the swinging - reverse to be turned on;
Delay parameter - minimum;
Limitation of the servo motion - maximal motion with no limits;
Exponents and proportions - not to be used;
Reaction speed - maximal;
Servo type - establish according to the factual;
Work mode - necessarily "Rate" or "Normal"
Adjustment of gain rate is as follows:
Start with maximal reaction rate. If mechanism starts to tremble when gimbal is not moving then lower the reaction rate. Push the gimbal with You finger – it has to move back smoothly to its place with no swinging. If swinging appears than gyroscope reaction is insufficient, increase the gyroscope gain value. If during maximal gain rate swinging is noticeable following may help: use faster servo with minimal dead band, use more tight springs, use another gyroscope. When the equipment is turned on, the gimbal must be stable, otherwise the gyroscopes will be initialized incorrectly and the camera will be tilted. If the onboard controller generates a high-frequency PWM signal, some simple gyroscopes may not work.
StandartinėParašytas: 19 Gru 2012 20:01
Hexas is garazo iskeliavo, tai vel prie savojo H6 prisedau. Sudejau motormountus ir primontavau pitch serva. Cia bene vienintele vieta, kur ja galejau montuoti- ant pacio gimbalo vamzdio bus roll serva ir kita nbetilps, ant gimbalo lopsio irgi netelpa (t.y. ziauriai sumazintu gimbalo eiga), ant gimbalo sono jau per arti propo gausis. Apacioj sumontavus servos alkune gali gauti nuo siubuojancio vamzdzio, bet vistiek turiu ten vietos gimbalui siubuoti i ta puse apie 45 Laipsnius. Kol kas svoris su gimbalo lopsiu ir motormountais yra 492gr- tenkina :)
StandartinėParašytas: 19 Gru 2012 20:22
Atrodo kūl!
Gal ir kelionę atidėjai? Čia pas mus šiaip dangus su žeme maišos, kamPščiai belenkokie, pusnys... Pavojinga ;-)
...o tuo tarpu ir copterius užbaigtum! =)
StandartinėParašytas: 19 Gru 2012 22:00
StandartinėParašytas: 19 Gru 2012 22:13
StandartinėParašytas: 19 Gru 2012 23:23
StandartinėParašytas: 20 Gru 2012 02:03
Parsiveziau namo Hexiuka ir sedau prie nazos pajungimo.
Pasijungiau be gps, tik testavimui kaip skris. Su stock nustatymais opa ir skenda puikiausiai.
Likau ziauriai patenkintas. Lengvas vejelis pute, bet jo atrodo visiskai nebloske. Zodziu geriausia skraidykle kokia esu turejes. Super! Aciu dar karta SK8robo uz super duper darba!
Dabar liko tik pajunkt gps ir linksmiausia dalis nusireguliuot gimbala.
Dar vienas pastebejimas, naudojant kamera. Uzdejau placiakampe 16mm linze ant nex5n. Vel go nustebino, kad nei kojos nei propai nelenda i akis. Reikia palenkti paximaliai kad pamatyt viena ar kita dali, bet juk skraidant tvarkingai niekada nepasuki kopterio 70 laipnsiu kampu. kazkus nuo 60 laipsniu tik pradeda lysti krastukai ar tai propo, ar tai landing gearo. Taigi bus galima dar svorio sutaupyt (~120gr) skraidant lengvesne linze :)
StandartinėParašytas: 05 Sau 2013 01:57
Nu ka, kolega Liutas zenyjasi Las Vegase vietoj to, kad gimbala nusistatinetu, o as toliau darbuojuosi prie savo H6 :) Mysle uz saldaini- kas cia?
Ir dar viena foto, kad butu lengviau :P
StandartinėParašytas: 05 Sau 2013 10:19
Nu gražu ;-)
Tik man atrodo kad bišky per daug išlengvinai - turėsi vibracijų, kurias bus sunku išnaikint.
Niekad nemėginai daryt taip - išlengvint, bet šalia (su epoxy) klijuoti statmenai tokios pat medžiagos juosteles? Kitaip sakant, daryt "U" formos ar "L" formos sutvirtinimus?
Aš mėginau taip su vienu gimbalu - rezultatai labai neblogi gavosi - ir lengva, ir tvirta, tik kad darbo daug ;-)
StandartinėParašytas: 05 Sau 2013 11:39
Jau kaip ir apsizenyjau :)
Taip ir nepavyko nustatyt man idealiai gimbalo.
Atrodo lyg pradejo veikt, bet pamesdavo gimbalas centrini taska.
Greit grysiu ir gal vis tik pavyks susineket
StandartinėParašytas: 05 Sau 2013 12:33
