Dabar yra 09 Spa 2026 20:28
Naujos temos kūrimas Atsakyti į temą  [ 1702 pranešimai(ų) ]  Eiti į Ankstesnis  1 ... 23, 24, 25, 26, 27, 28, 29 ... 114  Kitas
 Pranešimo tema: Re: BAJA [ bendri klausimai]
StandartinėParašytas: 06 Vas 2011 20:14
Užsiregistravo: 19 Kov 2009 16:19
Pranešimai: 93
Miestas: Alytus
Sveiki, turiu klausimeli: kuo skiriasi 5T ir naujasis 5SC?
StandartinėParašytas: 06 Vas 2011 20:28
Pranešimai: 298
Skaityk iki galo ir megaukis. :)
If you take off the tires, wheels, and the body, both a 5B and a 5T are identical. All of the parts interchange, same suspension, same engine, etc. The 5T has a 19T intermediate gear in the transmission, and the 5B has a 20T, so there is a gearing difference as well.
The 5B's handle better because they are lighter, significantly (6#'s or so) due to less body, less wheel and tire, and significantly less bumper and body mount.
The 5T's work better in the rough, and jump better because of the heavier weight, larger diameter tires, and the bumpers.
A 5B uses a lower profile and wider rear tire that has a smaller roll-out than a 5T rear tire. The wheel diameters are the same, the widths are different (5B wider) and the tire diameters are different (5T is larger).
I race both, I prefer the buggy on the track, and the truck everywhere else. The buggy is just less of a wrestling match on a track, unless the track is twice the size of Barona, very large (Milestone's Bajacross track or Phatdad's track are good examples).
The 5B and the 5T both have the same top speed, but the 5B gets there quicker, again due to less weight. The gearing change in the truck trans is just to compensate for the larger tire diameter the truck uses.
All of this holds true for the new 5SC as well. Take off the body, wheels and tires, and it is the same vehicle as a 5B or 5T and again all of the parts interchange. The 5SC does have some new upgrades in it which are nicer than the old style 5B and 5T parts. Namely the new rear hubs, larger dog bones, and the front hubs retained by screws instead of c-clips.
I am not trying to come off as a know it all, sorry if it sounds that way? I just own both of the vehicles, and have been racing them for a little over a year now and so thought I would chime in with the scoop...
Buy any one of the 3 (5B, 5T, or 5SC) and you'll really like it! I love mine, and personally I would recommend the new 5SC.
Hpi baja v2.0 30cc
StandartinėParašytas: 06 Vas 2011 20:40
Pranešimai: 93
Miestas: Alytus
O ka reiskia tasai terminas "short course"?
StandartinėParašytas: 06 Vas 2011 20:53
Pranešimai: 298
Tai reiskia specifini modeliu tipa. Na siuo atveju tai tik kebulo tipas
Hpi baja v2.0 30cc
StandartinėParašytas: 13 Vas 2011 21:01
Nu kaip bajistai gyvena? Tylu ramu ,ka bijot ziemos? :D
Seip kaip patarima ziemai vazinet tai siulau butinai susidet langus (ar kazka panasaus ,kad uzdengt sonus) nes kai filtras sniegu pasidengia baja sustoja :D IR dar kokiu tai tepalu istept gazo trauke visa ,nes apsala ties karbu ir baja nesustoja ,del padangu tai meginau dyglius ,bet po keliu litru nekas beliko ,gal kad buvo padangos jau plonos.
Dygliai (kaina ~15lt)
Po 2-3 litru
Grandines (kaina ~10lt)
Po 1 litro
Seip efektas labai panasus ,dygliu pliusas kad ant pliko ledo geriau kabina ,ir jei geros padangos ilgiau laiko ,grandiniu ,ad nesugadini padangu ,lengvai ir greitai gali uzdet/nuimt, geriau kabina sniega (gilu) bet minusas kad greiciau sudyla jei pabini smelio/zvyro o juolab asfalto :)
StandartinėParašytas: 13 Vas 2011 21:41
Pranešimai: 93
Miestas: Alytus
Blecha seiles tysta, taip svajoju apie baja, kad sunku jau darosi gyvent :).
StandartinėParašytas: 13 Vas 2011 22:33
Pranešimai: 936
Neuzmigom ;)
Paprasciausia laukiau kol kas atgaivins tema ;)
Ryt imesiu foto ir video su dygliais
p.s. siandien pameciau 4 spyglius :(
Skype: robis-ut-lt
+37061011450
²º15
StandartinėParašytas: 13 Vas 2011 22:41
tau gerai ,as per diena kai litra iskurenau tai mazdaug 50 dygliu pameciau :D
StandartinėParašytas: 13 Vas 2011 23:06
Yra
StandartinėParašytas: 13 Vas 2011 23:12
Pranešimai: 610
Miestas: ViLnIus
:liux Perkam luzusias detales, ir vel 'ant kalnelio'
Futaba 4pk
Losi SCTE
StandartinėParašytas: 13 Vas 2011 23:15
Kas perka o kas ne (sun)
StandartinėParašytas: 14 Vas 2011 14:25
Pranešimai: 1315
Kas neatlaikė ,palužo?Šeip gan efektyvios tos grandinės tokiai dangai ir gan šauniai per ta kalneli pasivažinėjote.
Skype ( Shmikis. )
StandartinėParašytas: 14 Vas 2011 14:40
Pranešimai: 936
Prisegu dygliuota padangą, va tik video tai pasirodo ir neturiu, kur lauke važiavau.
dygliai.JPG [ 63.05 KiB | Peržiūrėta 1317 kartus(ų) ]
Skype: robis-ut-lt
+37061011450
²º15
StandartinėParašytas: 14 Vas 2011 15:06
neblogai atrodo ,ziuresim kaip laikys ,bet kaip ir sakaiu ant sniego geriau grandines ,seip luso Edgai galinis c-hubas ,kai su savo luzusia sake triktelejau jam y rata :D Po to dar pulstarta nurove vaikis...
Del kalnelio tai veliau ant geresnio roviau ,bet camera-man'as jau buvo i raga susales tai nefilmavo ,seip veliau variau dar smagiau ,piestu i kalnely versdavo :DDD
StandartinėParašytas: 14 Vas 2011 22:47
Pranešimai: 575
Kur grandines pirkai,senukai? kaip tvirtinai? :D
Hot Bodies Cyclone WCE
Hpi Baja 5b SS
Hpi Savage Flux HP
