Dabar yra 20 Spa 2026 15:45
 Pranešimo tema: 1.2GHz Low Pass Filter
StandartinėParašytas: 06 Lap 2012 13:55
Užsiregistravo: 02 Lap 2010 22:15
Pranešimai: 369
Miestas: Raseiniai
1400mhz low pass filter
Product Description
1.2GHz Low Pass Filter attenuates RF noise which interferes 2.4Ghz RC receivers
Helps 1.2GHz Wireless Video Transmitter to prevent unwanted RF noises
12LPF 1.2G Low pass filters can reduce the interference to 2.4GHz receivers to prevent jitter servo issues. You may install it onto your receivers or transmitters, for filtering out unwanted RF noises.
Designed for 1200MHz -1390MHz wireless A/V transmitters. Low insertion loss, less than 0.7dB typical at 1300MHz.Passband DC - 1425MHz (<-1.5dB loss)Efficient monolithic LC multi-pole topography design.Second harmonic (> 2.4GHz) attenuation -35dB typical. SMA connectors (male / female).Inserts between transmitter and antenna. Characteristic impedance 50次.Handles RF power up to 8 watts.Small size, 1.45 x 0.31 x 0.25 inches (37 x 8 x 6.5 mm).
Characteristic impedance 50 ohm
Lightweight, 5.45 grams
Pradinė kaina - 20 lt,
Minimalus kėlimas - 5 lt,
Pirk dabar kaina - 50 lt
Aukciono pabaiga 2012-11-08 22:00
siuntimas - 5lt
RC avia modeliai
airboat
putinukas speed
1.2 Ikranas FPV
3m Ikranas FPV
TURNIGY 9x su frsky moduliu
TURNIGY accucell 6
TURNIGY accucell 8
 Pranešimo tema: Re: 1.2GHz Low Pass Filter
StandartinėParašytas: 06 Lap 2012 18:18
O nuoroda?
StandartinėParašytas: 06 Lap 2012 18:24
StandartinėParašytas: 06 Lap 2012 18:28
Pranešimai: 369
Miestas: Raseiniai
RC avia modeliai
airboat
putinukas speed
1.2 Ikranas FPV
3m Ikranas FPV
TURNIGY accucell 6
TURNIGY accucell 8
StandartinėParašytas: 06 Lap 2012 18:38
Pranešimai: 369
Miestas: Raseiniai
RC avia modeliai
airboat
putinukas speed
1.2 Ikranas FPV
3m Ikranas FPV
TURNIGY accucell 6
TURNIGY accucell 8
StandartinėParašytas: 06 Lap 2012 18:42
StandartinėParašytas: 06 Lap 2012 18:44
Pranešimai: 369
Miestas: Raseiniai
taip yra duomenys galiu nufotografuoti su filtru kartu
RC avia modeliai
airboat
putinukas speed
1.2 Ikranas FPV
3m Ikranas FPV
TURNIGY accucell 6
TURNIGY accucell 8
StandartinėParašytas: 06 Lap 2012 19:06
Pranešimai: 369
Miestas: Raseiniai
parduota buy now :)
RC avia modeliai
airboat
putinukas speed
1.2 Ikranas FPV
3m Ikranas FPV
TURNIGY accucell 6
TURNIGY accucell 8
