Dabar yra 24 Rgp 2026 19:58
 Pranešimo tema: Graupner MX-16s kokie sansai gauti lietuvoje?
StandartinėParašytas: 04 Geg 2006 23:52
Užsiregistravo: 30 Rgs 2005 09:19
Pranešimai: 21
Jau kazkuris laikas yra pasirodes naujas jr/graupnerio siustuvas MX-16s Seip turetu buti visai neblogas irenginukas MX-12 pakeisti ir smarkiai pigesne altarnatyva turinti sintezatoriu JR-9X`tam.. Idomu kokie butu sansai sita monstra gauti lietuvoje? Kainos graupnerio shope biskis uzlenktos..realiai turetu kainuoti kokius 250eu (lyginant pagal tai kiek kitur kainuoja MX-12), arba pvz galimybe isigyti tik siustuva?
Product information
High-technology micro-computer radio control system with new high-speed single-chip micro-computer, flash memory and 10-bit A/D converter. A computer radio control system with twelve model memories, carefully optimised and incorporating top-level technology. Modern computer system for unbeatable reliability. Simplified, straightforward programmingtechnique using rockers and momentary buttons. The high-contrast graphic screen provides an efficient means of monitoring set-up parameters, operating modes, timers and battery voltage.
- Modern hardware and integrated Synthesizer system for channel selection, with security menu to guard against setting the wrong frequency accidentally.
- Methods of operation and programming based onthe proven concepts of the mc-19 to mc-24.
- Eight control functions with extremely convenient, simplified method of assigning controls for auxiliary functions such as external switches and proportional controls.
- Unrestricted assignment of all switches to switched functions simply by operating the desired switch.
- Twelve model memories, the latest back-up systemrequiring no Lithium battery.
- Four switches (of which one is a three-position switch), one momentary button, one analogue control, two digital controls installed as standard; freely programmable for extreme flexibility.
- Function encoder with two rocker buttons and two momentary buttons for simplified programming and accurate set-up.
- CONVENIENT MODE SELECTOR provides simple method of switching the stick mode (modes 1 - 4, e.g. throttle right / throttle left).
- Graphical servo display provides a straightforward overview and a fast method of checking servo travels.
- Wing menu for: 1AIL, 2AIL, 2FLAP, V-tail, delta / flying wing and two elevator servos. Wing mixer:AIL diff, FL diff, AIL à RUD, AIL à FL, Brake à FL, Brake à AIL, ELE à FL, ELE à AIL, FL à ELE, FL à AIL and Diff. reduction; also receiver output swap.
- Heli menu: 1-point, 2-point, 3-point and 4-point linkages (1 SV, 2 SV, 3 SV (2 roll), 3 SV (2 pitch-axis), 4 SV (90°)
Selectable modulations:
SPCM
Super PCM modulation with high system resolution of 1024 steps per control function. For receivers: smc-14, smc-19, smc-20, smc-16SCAN, smc-19DS, smc-20DS, smc-20DSYN, smc-20DSCAN.
PPM 18
Eight functions, using the most widespread standardtransmission method (FM and FMsss).
For receivers:
C 12, C 16, C 17, R16SCAN, C 19, DS 18, DS 19, DS 20.
- Servo travel adjustment + 150% for all servo channels, variable for each end-point separately (Single Side Servo Throw).
- Sub-trim for fine-tuning the neutral position ofall servos
- Two-stage Expo / Dual-Rate system, separately variable, can be switched in-flight.
- Mixer functions:
aileron differential mixer, butterfly mixer, flaperon mixer and three freely programmable mixers.
- Programmable Fail-Safe function with hold-mode or preset function (SPCM only).
- Stopwatch / count-down timer with alarm function.
- Model copy function for model memories.
The sets contain:
mx-16S transmitter with Synthesizer transmitter module on the appropriate frequency band, integral 8NH-1700 mAh 9.6 V NiMH battery, R16SCAN receiver on the appropriate frequency, one C 577 servo, switch harness.
Specification
Transmission system: SPCM / PPM 18
Synthesizer RF section: 35 / 35 MHz B-band or 40 / 41 MHz band
Channel spacing, Synthesizer: 10 kHz
Max. control functions: SPCM = 8 / PPM = 8
Control functions: 8 functions, 4 with trims
Channel pulse width: 1.5 ms + 0.5 ms
Temperature range: -15 ... +55°C
Telescopic aerial: 10-section, approx. 1150 mm long
Operating voltage: 9.6 ... 12 V
Current drain approx. 225 mA (65 mA excl. RF)
Dimensions approx. 195 x 190 x 85 mm
Weight approx. 870 g incl. transmitter battery
StandartinėParašytas: 05 Geg 2006 17:44
Užsiregistravo: 11 Vas 2006 20:28
Pranešimai: 82
Kaina 249, pasirodyt pardavime turėtų vasarą (ne Lietuvoj, bet 13 EUR atstumu :). O pakeisti MX-12, kuris kainuoja 139 EUR - ne tam skirtas..Iki JR-9 MX-16'tam irgi kaip iki mėnulio :) Tai ir pagal indeksą jis tarp MX-12 ir MC-19 :)
StandartinėParašytas: 05 Geg 2006 18:18
Pranešimai: 21
Is esmes tai labai smarkiai patobulintas MX-12 ir pridetos f-jos kuriu truko ir paliktas tas pats korpusas. Pagal duota aprasyma panasiausias i futaba 7cap, taciau sintezatorius ir didelis ekranas uz beveik tokia pacia kaina (jei kainuos 249) smarkiai viliojanti perspektyva. Kas link JR-9, aisku pagal funkcionala ji ne konkurente, taciau tai turetu buti pigiausia ir su visais reikalingiausiais avia/heli navarotais aparatura turinti sintezatoriu! Visa kita pas 9`tuka kruti navarotai (be kuriu irgi gyvent pilnai imanoma), vardas ir prestizas, grazi grafika uz kuria moketi beveik dvigubai daugiau nesinori, todel akys ir krypsta i sita :-k Na kagi..reikia laukti kol pasirodys ](*,)
StandartinėParašytas: 06 Geg 2006 00:48
Užsiregistravo: 27 Geg 2005 10:40
Pranešimai: 190
Miestas: Panevezys
Tomai, o kur cia MX-12 uz 139,- eur ?
StandartinėParašytas: 16 Lie 2006 16:19
Užsiregistravo: 16 Lie 2006 16:12
Pranešimai: 20
Praėjo keli mėn.,gal kas turite šį MX-16S siųstuvą jau?
