Dabar yra 22 Lie 2026 08:33
 Pranešimo tema: skaitmeninis turnigy pakrovejas tik 120lt
StandartinėParašytas: 08 Rgp 2009 10:50
Pranešimai: 693
parduodu stai toki pakroveja, kompiuterizuotas gali krauti visu tipu akumus (naudojamus rc modelizme) naudotas, bukle gera, viskas veikia :) kaina 120lt
Stai visa info apie ji :
The Turnigy Accucel 6 is an entry level balancing charger and discharger which can handle up to 6 cells and 5A.
The Accucel-6 will handle LiPo/LiFe up to 6S and NiMH/NiCd up to 15S and shows individual cell voltage during charge with realtime updates throughout the charge cycle.
Bundled with the Accucel-6 is a bunch of input and output wires which should satisfy any charging requirement.
Features;
Microprocessor controlled
Delta-peak sensitivity (NiMH/NiCd)
Individual cell balancing
Li-ion, LiPo and LiFe capable
Ni-Cd and NiMH capable
Large range of charge currents
Store function, allows safe storage current
Time limit function
Input voltage monitoring. (Protects car batteries at the field)
Data storage (Store up to 5 packs in memory)
Battery break in and cycling.
Spec.
Input Voltage: 11~17v
Circuit power: Max Charge: 50W / Max Discharge: 5W
Charge Current Range: .1~5.0A
Ni-MH/NiCd cells: 1~15
Li-ion/Poly cells: 1~6
Pb battery voltage: 2~20v
Weight: 355g
jai nemokate angliskai ar kilo kokiu nors klausimu mano kontaktai apacioje
ACC6(1).jpg [ 60.17 KiB | Peržiūrėta 821 kartus(ų) ]
skype-garson2886
tel-86penki387491
StandartinėParašytas: 08 Rgp 2009 11:54
Pranešimai: 439
Miestas: ALYTUS
gal galima real foto? Nes cia tai foto ideta is google :)
Sanwa RD8000 35MHz | SUltimate F3P | Morback F3P | Spark F3P gaminamas | Putinukai | F3K Spinnin birdy gaminamas | Turnigy accucel-6 | Future F3P |Mini F3K Pulis 60cm |
