Dabar yra 23 Lie 2026 12:21
 Pranešimo tema: Imtuvas R921 2.4 Ghz
StandartinėParašytas: 31 Lie 2009 22:04
Pranešimai: 333
Miestas: Trakai - Vilnius
Kaina 450LT (Naudotas apie 5men, crashu neturejas)
The R921 combines an internal and remote receiver, offering superior path diversity. The radio system simultaneously transmits on two frequencies, creating dual RF paths. This dual path redundancy, plus the fact that each of the two receivers is located in a slightly different location exposes each to a different RF environment and creates a superior path diversity RF link in all conditions.
JR remote receiver is compatible with all Spektrum and JR aircraft receivers that utilize remote antennas.
The R921 requires at least one remote receiver be used, but can use a second remote receiver if desired.
The original JR air receivers introduced some amazing technology to the air market, and the R921 continues that proud tradition of pushing the technological envelope. Taking DuaLink to the next step, the R921 ensures that you have the best RF link possible while providing the precision and control you need to fly with confidence. The R921 could almost be referred to as a receiver system, as it can utilize up to four receivers at any one time. Two main receivers are built into the casing of the R921 itself, while much like the AR7000, an additional remote receiver plugs into the main unit. In some installations, such as high-performance jets, it may be desirable to add in an additional fourth remote receiver. Doing so allows the R921 to see more of the broadcast signal than ever possible before, providing the most precise control and locked-in feel on the market.
The R921 features DSM2TM technology and is only compatible with DSM2 transmitters.
The R921 will not operate with the DX6 or Spektrum surface systems.
Marius
JR 11X 2.4Ghz
StandartinėParašytas: 02 Rgp 2009 13:15
Pranešimai: 333
Marius
JR 11X 2.4Ghz
StandartinėParašytas: 09 Rgp 2009 19:48
Užsiregistravo: 18 Bir 2009 18:04
Pranešimai: 95
StandartinėParašytas: 10 Rgs 2009 19:26
Pranešimai: 333
Marius
JR 11X 2.4Ghz
