Dabar yra 16 Lie 2026 16:37
 Pranešimo tema: parduodu varikliuka Aeolian 33gr 1400kv ESC HiModel FLY-20A
StandartinėParašytas: 23 Lie 2009 19:47
Pranešimai: 562
parduodu puikiai veikianti motoriuka Aeolian 1400kv 2822 KAINA 40lt
320W
Continuous Current 15 A
Max. Current 20 A
Input Voltage 6 - 11.1 V
Max. Efficiency 98 %
No Load Current 0.6 A
Internal Resistance 101 m(Omega)
Rotational Speed 1400 (kv) RPM/V
Motor Weight (Motor only) 33g
Motor Dimensions (Diameter x Length) 28* 23.1 mm
Propeller Dimensions 7.5" *3.5" / 8" *4" / 9" 5"
Input Battery Types NiCd / Nimh/ Li-po Battery
Recommend Model Airplane
HiModel FLY Brushless Speed Control Type FLY-20A
Type: FLY-20A
· Weight: 18g
· Size: 32 x23 x7 mm
· Constant Current:20A
· Max Current:25A (for ten seconds)
· FET: 12
· BEC: Yes, 2A
· PWM: 8 KHz
· Input: 2 to 3 Li-Po, or 6 to10Ni-MH/Ni-Cd
KAINA 30lt
perkant KOMPLEKTA KAINA TIK 50LT
8 sesi 8 tris 8 tris 7O7
StandartinėParašytas: 24 Lie 2009 06:36
Pranešimai: 562
