Dabar yra 16 Bal 2024 19:22
 Pranešimo tema: pakrovejas/iskrovejas Jamara X-PEAK Premium
StandartinėParašytas: 07 Sau 2009 11:29
Pranešimai: 1580
Naujas, supakuotas dezuteje! Kaina 459Lt
Technical data: - Input tension: 11-15 V DC - accumulator types: 1-30 NiCd-and NiMH cells, 1-12 LiIo-and LiPo-and LiFe cells, 1-6 Pb cells - charging current: 0.1 A-10,0 A (step width 0.1 A) - Entladestrom: 0.1 A-10,0 A (step width 0.1 A) - preservation charging current: 0-500 mAH (with Ni cells) - loading method: Delta-Peak procedures with NiCd-and NiMH accumulator, steady stream/-spannung with Li and Pb accumulators - display: zweizeilig with 16 signs, blue illuminated - announcements: Case or Entladestrom and time, accumulator tension, loaded or unloaded capacity, care tension, delta Peak tension, with Li cells single tension, error messages - protective functions: Verpolungsschutz at the entrance and exit - dimensions: 171 x 148 x 68 mm - weight: approx. 690 g - Einzelzellenspannungsanzeige for Li stack by use of the Intelli-Balancers
Daugiau info PM ar Tel. Nr
Siunciu i visus miestus NEMOKAMAI !
XRAY 808'11
XRAY 808e
MCD RR V4
http://www.RCSERVISAS.lt
+37061012888 www.astuoni.lt
