Dabar yra 22 Spa 2026 10:27
 Pranešimo tema: Motoras saliniams modeliams ("kryþiukams")PARDUOTA
StandartinėParašytas: 14 Lap 2008 13:32
Užsiregistravo: 02 Bal 2008 07:53
Pranešimai: 49
Nenaudotas HYPERION Z1705-14 17g. puikus, kokybiškas motoras lengviems saliniams modeliams 90Lt.
With the Z17 series motors Hyperion brings you the most capable, reliable motors in their weight class, and more peak power per gram than any competitor. We get more peak power by using the finest materials and intelligent design. For example, the magnets and coil wire are the best you can get, with temperature rating of 180C (compared to the typical 120C types). This means that you can push the motors harder than others when needed, without damage to the motors. We also use thinner stator plate material than some other brands, and that material is the best available from Japan. This results in a net performance increase of up to 5% over competitors.
Stator Diameter mm 17.0 (9 poles)
Magnet Length mm 5.0 (12 magnets)
Weight g 17
Outside Diameter mm 20.9
Motor Length mm 17.5
Mount Screw Diameter mm 2x M2.0, 12mm and 14mm spacing (14mm set used for backplate)
Max efficient Current A 4.0A
Max Continuous Current A 7.0A*
LiPo cells typical "S" 1S to 3S
Resistance Ohm 330.51 mΩ
Io A @ 8.4V 0.57A
KV rpm/V 1800
http://media.hyperion.hk/dn/motor/z17/z17-propdata.pdf
HYPERION Z1705-14 rezervuotas.
