Dabar yra 28 Spa 2026 01:02
 Pranešimo tema: 4x skaitmenines JR servos
StandartinėParašytas: 25 Spa 2008 09:15
Užsiregistravo: 11 Bir 2005 19:52
Pranešimai: 239
Miestas: Klaipeda
4x skaitmenines JR servos Ds821
viena is servu nebuvo isvis naudota, likusios stovejo trex600.
bukle labai gera.
uz visas 220
http://www.jrradios.com/Products/Defaul ... ID=JRPS821
DS821 Digital Sport High Torque Servo
Specs
Size Category: Standard
Type: Digital
Torque: 72 oz/in @ 4.8v, 88 oz/in @6v
Speed: .19 sec/60° @ 4.8v, .15 sec/60° @ 6v
Dimensions (WxLxH): 0.74"x1.50"x1.47"
Weight: 1.5 oz
Bushing Or Bearing: Bearing
Bearing: Single
Motor Type: 3-pole ferrite
Gear Type: Nylon
Gear Material: Composite
Application: Standard size-digital servo upgrade for sport pilots
Tech Notes
The DS821 servo is a powerful, accurate sport digital servo recommended for RC airplane applications up to 1.20-size. For helicopters, the DS821 operates best with 30-size glow models, and up to 50-size electric. Loads and vibration in larger models may cause premature failure of the servo resulting in damage or injury to property and persons.
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
StandartinėParašytas: 25 Spa 2008 09:19
Pranešimai: 693
sudek viska i viena linka tersi foruma.
StandartinėParašytas: 25 Spa 2008 10:19
Pranešimai: 239
Miestas: Klaipeda
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
StandartinėParašytas: 25 Spa 2008 10:22
Pranešimai: 693
StandartinėParašytas: 25 Spa 2008 10:48
Pranešimai: 239
Miestas: Klaipeda
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
StandartinėParašytas: 25 Spa 2008 11:34
Pranešimai: 693
as tau uzdrausti nieko tau negaliu. tiesiog kodel negalejai ideti i viena skelbima?
StandartinėParašytas: 25 Spa 2008 13:25
Pranešimai: 439
Miestas: ALYTUS
Sanwa RD8000 35MHz | SUltimate F3P | Morback F3P | Spark F3P gaminamas | Putinukai | F3K Spinnin birdy gaminamas | Turnigy accucel-6 | Future F3P |Mini F3K Pulis 60cm |
StandartinėParašytas: 06 Lap 2008 23:51
Pranešimai: 239
Miestas: Klaipeda
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
