Dabar yra 22 Spa 2026 08:54
 Pranešimo tema: FUTABA GY401 ir greita serva
StandartinėParašytas: 25 Spa 2008 09:06
Užsiregistravo: 11 Bir 2005 19:52
Pranešimai: 239
Miestas: Klaipeda
FUTABA GY401 ir greita robbe fs 200 serva.Stovis idealus- labai mazai naudota.
tik 380lt
serva:
robbe fs 200
A reasonably priced high-speed tail rotor servo for electric helicopters and glow-powered helicopters with motors up to about .46 size. The plastic gearbox is of robust construction, and the output gear runs in twin ballraces. A spezial potentiometer ensures accurate positioning and reliable neutrals. The Indirect Drive System shields the potentiometer from vibration.
Dimensions: 40 x 19,7 x 37,8 mm
Mass/weight: 45.00 pond/g
Operating voltage: 4,8 - 6 Volt Volts
Transit speed: 0.10 Sec/45°
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
