Dabar yra 22 Spa 2026 08:19
 Pranešimo tema: 3x skaitmenines servos futaba 3151
StandartinėParašytas: 02 Spa 2008 14:13
Užsiregistravo: 11 Bir 2005 19:52
Pranešimai: 239
Miestas: Klaipeda
labai mazai naudotos- stovis idealus.
kaina 150lt
Manufacturer Futaba
Type Digital Standard
Torque 4.8V 43 oz/in (3 kg/cm)
Torque 6.0V 56 oz/in (4 kg/cm)
Speed 4.8V 0.21 sec/60 degrees
Speed 6.0V 0.17 sec/60 degrees
Dimensions 41mm x 36mm x 20mm
Weight 43g
Bearings Dual Ball Bearing
Gear Type Nylon
Applications:
- Basic Trainer
- Electric Aircraft
- Large Electric Aircraft
- Standard Helicopter
- Standard Sailplane
- Standard Airplane
- All Purpose
- 30-sized Helicopters
- Sport
- 15-sized Helicopter
- 46-sized Helicopter
- Recreation
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
StandartinėParašytas: 09 Spa 2008 13:18
Pranešimai: 239
Miestas: Klaipeda
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
