Dabar yra 21 Spa 2026 06:40
 Pranešimo tema: Governorius RCE-G600
StandartinėParašytas: 28 Rgp 2008 16:07
Užsiregistravo: 15 Rgp 2007 11:25
Pranešimai: 113
Miestas: Rokiskis
Parduodu mazai naudota governoriu Align'o RCE-G600, kas reikia sito daikto tam pristatineti nereikia, bet stai dar charakteristika:
Instruction:
*Compact design, easy use, simple setting with great speed control performance.
*Speed resolution: 0.1RPM
*Speed stability accuracy: within 1%(Steady State)
*Not apply to S9251¡BS9256 and other 760£gs servos.
Specification:
*Operating voltage:DC4.5V-6V
*Consumption current:<20mA@4.8V
*Direct detection of engine rotation speed.
*Speed control range:10500~21000RPM
*Servo RWM output pulse width: 1~2ms¡Anot apply to S9251¡BS9256 and other 760£gs servos.
*Operating temperature range:-20¢XC~85¢XC
*Operating moisture range:0%~95%
*Case size(body):28.5x26.2x9mm
*Signal wire length:160mm
*Sensor wire length:250mm
*Weight:10g(including wires)
Accessories:
*RPM Magnet x 2(f4x1.5mm)
*Socket button head screw x 2(T2.6x6mm)
*Nut x 1
Kaina 100lt
Kreiptis PM, tel.:860001461, Skype Suopinis_Zhveris
T-800 Big Scale Heli (progressing)
T-rex 700 (coming soon)
Blade
Pitts Challenger (in progress)
Putinukas 3D
JR 9503
Parduodu putinukus
