Dabar yra 22 Spa 2026 09:42
 Pranešimo tema: LRP bullet Reverse reguliatorius be limitu
StandartinėParašytas: 06 Bir 2008 15:55
Užsiregistravo: 28 Lap 2005 21:21
Pranešimai: 210
Miestas: Panevezys
Parduodamas naudotas reguliatorius LRP Bullet Reverse be limitu.
Naudotas 2menesius. Geros bukles. Visas komplektas dezuteje.
Kaina 255litai.
Specification
Rec. Motor Limit (at 6 cells--7.2V)
no motor limit
Forward/ Brake/ Reverse
yes
Voltage Input
4-7 cells (4.8-8.4V)
Rated Current
225A
Typical Voltage Drop at 20A (Transistors rating at 25 deg. C junction temp.)
0.048V
B.E.C.
5.0V
High Frequency
yes
Fail-Safe System
yes
Multi-Protection System
yes
Connectors
Standard Tamiya style
Setup procedure
automatic (pull throttle to set up)
Features:
Intelligent automatic setup.
Forward/Brake/Reverse operation.
Fail-Safe function.
Integral Heatsink.
Reverse Polarity, Overload, and Thermal protection.
Motor and battery connectors already installed ... no soldering needed!
Size & Weight:
Case Size: 42.5mm x 42.5mm
Weight: 51.0g
