Dabar yra 18 Lie 2026 13:15
 Pranešimo tema: PARDUODU skaitmenini pakroveja HYPERION su balansyru.
StandartinėParašytas: 29 Geg 2008 23:38
Pranešimai: 1161
Miestas: Kaunas Vaiðvydava
Naudotas tik savaite laiko.
Pinai krauna 10A srove 6 -7 celes tiek A123 tiek Li-Po akumuliatorius.
10 akumuliatoriu atmintis.
Krauna visu tipu akumuliatorius.
Kaina tik 550LT :)
Tel 862222100 Kaunas
Daugiau informacijos:
Charges NIMH, NICD, Lipo & A123
Comes with Integrated LBA Balancer
Also includes Hyperion 2S-6S Multi-Adapter
1-16 NIMH-NICD, 1-6 Lipo, 1-6 A123 cells
Up to 10 amp charge rate
250 Watt max charge output
Capable of quick 2C charge rate
Comes with a data port
This charger is incredibly versatile and has 3 available modes!
Charge only mode
Balance Charge mode
Balance only mode
You may "Network" connect 2 EOS610i's together, using optional EOS0610 network cable. In this case, you can charge 2 separate but similar Lipo or A123 packs as a single unit, to make packs from 7S to 12S at 500W max charge power.
Terminal Capacity Selection (TCS)
Temperature Sensor Port
10 User-definable Memory Position
