Dabar yra 20 Spa 2026 05:51
 Pranešimo tema: Kyosho Fazer Pure Ten GP Subaru Impreza WRX 2007 nitro / RTR
StandartinėParašytas: 04 Bal 2008 15:04
Pranešimai: 1580
Pirkau Nauja is parduotuves grazioje dezuteje su dokumentais.
Modelis galima sakyti naujas, nes pakeistas Naujas variklis, apkatke nepadaryta. Vazineta nedaug.
Pilnai paruostas vaziavimui.
Truksta akumuliatoriu ir kuro.
Viskas graziai supakuota dezeje:kuro buteliukas, dokumentai, zvakes pakaitintojas, padovanosiu dar viena gera nauja pakraunama zvakes pakaitintoja, visraktis.
Tech Spec:
World Championship winning machines has been fully applied in the creation of an entry-level GP touring car.
Factory-assembled Readyset package only needs batteries and fuel to roar to life.
Shaft-drive 4WD chassis produces easy control response ideal for beginner racers.
Slide carburetor delivers sharp acceleration (MAX 70km/h).
Newly developed diecast muffler generates powerful but gentle output.
A total of 18 bearings used through the high-efficiency drive train for full-bearing specifications.
Installed with KT-3HS 2-channel R/C system with digital servos for sure control response.
Rigid axle with two-bevel diff gear on rear results in the mild control characteristics.
75cc fuel tank with choke button gets fuel flowing with one-touch.
Duomenys:
Ilgis 383mm
Plotis 200mm
Aukstis 92mm
Aukstis nuo zemes shasi 10mm
Ratu baze 260mm
Svoris 1,775kg
Variklis GZ-15 with Recoil Starter
KAINA 600lt, galima deretis.
Daugiau info tel. 860048598 arba 869819940 arba PM . Galiu atsiusti i bet kuri miesta.
SNC11361.JPG [380.54 KiB]
Atsisiųsta 397 kartus(ų)
SNC11357.JPG [347.61 KiB]
Atsisiųsta 300 kartus(ų)
SNC11362.JPG [386.87 KiB]
Atsisiųsta 273 kartus(ų)
XRAY 808'11
XRAY 808e
MCD RR V4
http://www.RCSERVISAS.lt
+37061012888 www.astuoni.lt
Paskutinį kartą redagavo [LRS] 05 Geg 2008 19:06. Iš viso redaguota 1 kartą.
StandartinėParašytas: 08 Bal 2008 21:46
Pranešimai: 1580
XRAY 808'11
XRAY 808e
MCD RR V4
StandartinėParašytas: 12 Bal 2008 23:16
Pranešimai: 1580
XRAY 808'11
XRAY 808e
MCD RR V4
StandartinėParašytas: 05 Geg 2008 19:07
Pranešimai: 1580
SKUBIAI
KAINA 500lt atsiusti galiu i bet kuri miesta !
XRAY 808'11
XRAY 808e
MCD RR V4
StandartinėParašytas: 07 Geg 2008 01:04
Užsiregistravo: 07 Geg 2008 01:00
Pranešimai: 23
StandartinėParašytas: 07 Geg 2008 06:38
Pranešimai: 1580
XRAY 808'11
XRAY 808e
MCD RR V4
