Modelis pirktas (naujas) Anglijoje s.m Sausio men.
Vazineta tik 2L firminio o'Donnell kuro.
Kebulas turi kelis ibrezimus.
Pilnai paruostas vaziavimui.
Deze,dokumentai, zvakes pakaitintojas,visraktis
(truksta buteliuko kurui pilti ir kebulo segtuku).
KAINA: 550lt kaina derinama proto rybose (rasyti i PM arba skambinti tel:861023828...867261524)______________________________________________
Tech Spec:
World Championship winning machines has been fully applied in the creation of an entry-level GP touring car.
Factory-assembled Readyset package only needs batteries and fuel to roar to life.
Shaft-drive 4WD chassis produces easy control response ideal for beginner racers.
Slide carburetor delivers sharp acceleration (MAX 70km/h).
Newly developed diecast muffler generates powerful but gentle output.
A total of 18 bearings used through the high-efficiency drive train for full-bearing specifications.
Installed with KT-3HS 2-channel R/C system with digital servos for sure control response.
Rigid axle with two-bevel diff gear on rear results in the mild control characteristics.
75cc fuel tank with choke button gets fuel flowing with one-touch.
Chassis Technical data:
Length 383mm
Width 200mm
Height 92mm
Ground Clearance 10mm
Wheelbase 260mm
Tread (F & R) 176mm
Tires (F / R) ¯’³ 64?~24mm
Gear Ratio 7.63 / 5.33?F1
Weight 1,775g (approx.)
Engine GZ-15 with Recoil Starter
| Prikabinti failai: |
Failo aprašymas: Nuotraukoje nera 2 kanalu Perfex siustuvo.....
IMGP1903.JPG [ 61.92 KiB | Peržiūrėta 1595 kartus(ų) ]
IMGP1907.JPG [ 52.34 KiB | Peržiūrėta 1594 kartus(ų) ]
IMGP1904.JPG [ 51.49 KiB | Peržiūrėta 1595 kartus(ų) ]
_________________ BMI DB10RR /HBW XERUN-120A-1S-SD (V2.1)/Speed Passion 17.5R
