Dabar yra 17 Spa 2026 22:00
 Pranešimo tema: Savage HP Flux XL. Fully Moded.
StandartinėParašytas: 09 Gru 2018 13:22
Pranešimai: 222
https://www.skelbiu.lt/skelbimai/savage ... 78775.html
Modai:
Leopard Hobby LBP4092-1480KV 4200W Motor
HPI ELC-6s ESC
Castle Creations Field Link Card
Alza XL 5mm Chasis - http://shop.alza-racing.com/en/xl-flux/ ... assis.html
Alza XL Rear Dogbone - http://shop.alza-racing.com/en/xl-flux/ ... gbone.html
Alza Center Differential Kit - http://shop.alza-racing.com/en/standard ... l-kit.html
Alza Bulkhead Brace Conversion Kit - http://shop.alza-racing.com/en/savage-n ... n-kit.html
Vorza Center Differential - http://www.dollarhobbyz.com/products/hp ... fferential
RPM Lower Arms Front + Rear
HPI Racing Savage HP Suspension Conversion - HPI87245 - https://www.amainhobbies.com/hpi-racing ... 45/p148221
HPI Super Heavy Duty Wide Axle - HPI86249 - https://www.amainhobbies.com/hpi-racing ... 49/p104612
Warlocks + Terra Pins with tape inside
HPI 17mm Hex Conversion with Titanium Nuts
HD Servo Saver Spring
HD Alu Servo Arm
HiTec 7955TG 24kg Titanium Gear Servo - https://www.amainhobbies.com/hitec-hs79 ... 55s/p25352
Bashed smashed taped zipped Savage XL Body
Dabar stovi Leopard'as, kartu atiduodu Flux Tork 2200kv motor originalų motorą.
Kelios baterijos i komplektą.
Kruva atsarginiu daliu.
Kaina 550Eur
8656 22du72
