Dabar yra 23 Lap 2026 15:09
 Pranešimo tema: Parduodu 4 x regus Emax BLHELI 20A BL ESC
StandartinėParašytas: 23 Bal 2018 21:03
Užsiregistravo: 22 Kov 2009 10:17
Pranešimai: 5
Miestas: Klaipeda
visiškai nauji, nenauduoti
Kaina uz 4 vnt. : 20 EUR
- Rotation direction of the motor is programmable: normal, reverse or bidirectional
- All parameters can be programmed via using a program card or a transmitter, including default settings
- Multiple protection features including low voltage cut-off protection/over-heat protection/throttlesignal loss protection
- Alarm to help you find the devices: keep the throttle on FULL ON position for a while, the ESC will help
- Throttle range can be configured and is fully compatible with all receivers, providing smooth, linear and precise throttle response
Specifications:
- Continuous current: 20A
- Burst current: 25A@10S
- Lixx battery: 2-4S
- Dimension: 52*26*7mm
- BEC output: 2A 5V
- Weight: 28g wires included
- Programmable
HTB12DVOQVXXXXXXaXXXq6xXFXXXI.jpg [88.77 KiB]
Paskutinį kartą redagavo Vit__ 25 Bal 2018 21:51. Iš viso redaguota 1 kartą.
 Pranešimo tema: Re: Parduodu rega YGE 120HV
StandartinėParašytas: 24 Bal 2018 11:47
Užsiregistravo: 24 Bal 2018 11:21
Pranešimai: 1
Paskambink Gyčiui 868655806 Gargždai.
