Dabar yra 17 Bal 2024 02:01
 Pranešimo tema: Hobbywing Platinum 100A Pro ESC
StandartinėParašytas: 22 Lie 2017 01:29
Užsiregistravo: 22 Lie 2017 01:11
Pranešimai: 1
Kaip nauja. Kaina 50EUR.
Vilnius
8-611 55555
Features
1.High performance microprocessor brings out the best compatibility with all kinds of motors and the highest driving efficiency
2.Max motor speed : 21000RPM (2 poles), 70000 RPM (6 poles), 35000 RPM (12 poles)
3.3 start modes : Normal / Soft / Very Soft, for Fixed Wing Aircraft or Helicopter
4.Adjustable throttle range
5.Smooth, linear, quick and percise throttle respond
6.Separate voltage regulator IC to minimize anti-jamming
7.Multi protection : Low-voltage cut-off protection / over-heat protection / throttle signal loss protection
8.Adjustable BEC : 5.25V or 6V
9.With Governor Mode for helicopter
10.USB supported. The firmware of the ESC can be updated by the USB adapter
11.Setup values with the Program Card (optional)
12.English Manual is included
Specification
Con. Current :
100A
Burst Current :
150A
Programmable :
Yes
Dimension (mm)
70 x 34 x 16
Weight :
82g
BEC Mode :
Switch Mode, 5.25V or 6V, 3A
Battery cell :
Li-PO : 2-6 cell / NiMH : 5-18
