Dabar yra 27 Lap 2026 01:20
 Pranešimo tema: Futaba 8FG Super + R6208SB
StandartinėParašytas: 12 Lap 2016 01:47
Užsiregistravo: 09 Bir 2015 13:39
Pranešimai: 2
Parduodu beveik nauja Futaba 8FG Super, 14 kanalu siustuva.
Yra originali baterija, EU pakrovejas, deze, instrukcija, imtuvas.
Taip pat pridedamas "throttle centration mechanism"
"Super-sized" with more channels — and CGY750 gyro support!
The original 8FG was already the best 2.4GHz radio value available. Now, for the same cost, the 8FG Super offers six additional channels — plus new software with menus tailored to Futaba's super-fast CGY750 gyro. Recommended by Bobby Watts, Matt Botos and Kyle Stacy, it's the first radio that really supports flybarless helicopters. And it's perfect for all other applications, too...a smart choice for ANY forward-looking flier.
New 8FG Super features :
Expanded with 14 total transmitter channels — 12 proportional and two switched.
Included R6208SB receiver's PWM (Pulse Width Modulation) channels support up to 8 standard analog or digital servos — and it handles up to 18 channels when used with an S.Bus system.
Gyro menu supports 3-axis gyros and is perfectly tailored to the CGY750.
User menu allows pilots to customize and display frequently used functions.
VPP (Variable Pitch Propeller) compatibility can be set to three conditions for throttle and pitch curve.
Swash trim can be adjusted from the swash screen.
Continued from the original 8FG :
SensorTouch™ programming maximizes navigation ease.
Numerous factory-defined mixes help you program like a pro.
Low latency and cutting-edge 2048 resolution combine for fast, accurate Real-Time Response™.
Accepts 32MB to 2GB SD memory cards* — add as much memory as you want. (*SD memory card not included)
Transmitter Overview :
12 proportional channels
2 switched channels
Integrated FASST 2.4GHz design
2048 resolution
Airplane, heli & glider software
20-model internal memory, unlimited with SD card
Compatible with 32MB to 2GB SD Memory Cards*
Mode 1-4 selectable
Customizable user menu
Direct access to timers, channel mode & model selection
2-touch access to system, linkage & model menus
Assignable switches/functions
10-character user & model naming
Model select, copy & reset
Data transfer
All-channel & battery fail-safes
Sub-trims, servo reversing, dual rates, expo & EPA with separate limit settings
Digital trims & memory, with step or % display option
128 x 64 backlit LCD w/auto-off timer, normal/large timer display options, adjustable contrast & brightness
Servo cycle w/bar graph displays
Model & system timers
Trainer system w/channel/function options
Sticks w/ball-bearing gimbals, length & tension adjustments
Stick calibration menus
299€
Vilnius.
futaba-min.JPG [135.54 KiB]
 Pranešimo tema: Re: Futaba 8FG Super + R6208SB
StandartinėParašytas: 21 Lap 2016 22:05
Užsiregistravo: 03 Gru 2014 23:39
Pranešimai: 8
Siulau 200 ? (happy) (happy) (tmi)
StandartinėParašytas: 02 Vas 2017 09:29
Užsiregistravo: 07 Rgp 2010 22:41
Pranešimai: 58
Radija dar turi?
