Dabar yra 18 Spa 2026 20:02
 Pranešimo tema: RMILEC TS4047P 10CH 2W UHF
StandartinėParašytas: 20 Kov 2016 12:27
Pranešimai: 1192
Miestas: Visa Lietuva
This LRS system is well made and perfectly fit JR/Futaba radios like FF9 10C 8fg etc . For other radios, you must do some wiring work to get ppm, V+ and GND from your radios and the system will work.
the new system is based on Ham band and neighbouring band from 400mhz-470mhz, with the frequency hopping technology and frequency sweeping technology ,you never need to worry about losing control of your precious plane.
Have short range trouble? this LRS has a range beyond your imagination. with a bad antenna, you may still get 20km range in the air ,and with a super good 1/2 wave length one ,you can even get 60km in the air
Parameters:
RF output:1000mw-2200mw
Power comsumption: 300-600mA
Range: 20-60km in the air
Failsafe: Yes
High and low power selection: 1000mw or 2000mw output
Highspeed control: yes
Naudotas, veikiantis be problemų. Kaina 99 eu.
 Pranešimo tema: Re: RMILEC TS4047P 10CH 2W UHF
StandartinėParašytas: 24 Bal 2016 12:52
Pranešimai: 1192
PARDUOTA
