Dabar yra 19 Spa 2026 01:39
 Pranešimo tema: Fatshark 700TVL, TGY-i10, Reaktor 250W, FR632 Diversity
StandartinėParašytas: 14 Gru 2015 22:53
Užsiregistravo: 02 Gru 2015 22:42
Pranešimai: 6
Parduodami nauji daiktai pirkti HK:
1) Fatshark 700TVL High Resolution FPV Tuned CCD Camera V2 (PAL) (EU Warehouse) - 38 Eur
4) Turnigy Reaktor 250W 10A 1-6S Balance Charger - 45 Eur
5) FR632 Diversity 5.8GHz 32Ch Auto Scan LCD A/V Receiver - 70 Eur
Vieta: Vilnius
1) Fatshark 700TVL - http://www.hobbyking.com/hobbyking/stor ... ouse_.html
Fatshark's CCD camera is a huge step in FPV specific products. Fatshark took Sony’s latest Super HAD CCD and optimized the settings for FPV by improving clarity, light handling when facing the sun as well as increased low light performance. The 25mm format makes this a small and lightweight camera perfect for pan and tilt systems.
Features:
• FPV tuned white balance and gain control
• 700 TVL high resolution camera
• Compact size
Specs:
Type: Colour
Signal System: PAL
Pick Up Device: 1/3” SONY Super-HAD CCD
Pixel: 726X 582
Resolution: 700 TV Lines
Min Illumination: 0.08 Lux /F1.2
Scanning System: 2:1 Interlace
Sync System: Internal
S/N Ratio: More than 55dB
Gain Control: Auto (FPV tuned)
White Balance : Auto (FPV tuned)
Lens: 3.6mm (no IR)
Video output: 1.0V p-p (75Ω BNC)
Power Supply: 3.3 – 5V DC
Power Consumption: 110mA
Dimensions: 27 X 25 X 13 mm (+14mm lens extrude)
Operating Temp: -10 to 50°C
2) Turnigy Reaktor 250W 10A 1-6S Balance Charger http://www.hobbyking.com/hobbyking/stor ... ouse_.html
Big power in a small package! The Turnigy Reaktor 250W charger is one of the most powerful chargers we have ever seen for its size. This high power balancing charger/discharger can provide up to 10A charge rates and handle up to 6S Li-poly/LiFe or 17S NiCd/NiMH accurately.
Not only does the Reaktor 250W offer a high charge rate capability, it also boasts great features such as storage charging, cyclic charging / discharging, 10 charge parameter memory and can also be set up as a convenient power supply for a hot wire foam cutter!
The Turnigy Reaktor 250W is an all-in-one power house charging solution for your R/C models' batteries.
Features:
• Microprocessor controlled
• Delta-peak sensitivity (NiMH / NiCd)
• Individual cell balancing charge & discharge
• Li-ion, Li-poly and LiFe capable
• Ni-Cd and NiMH capable
• High-power and high-performance circuit
• Store function, allows safe storage current
• Data storage (Store up to 10 packs in memory)
• Cyclic charging / discharging
• Convenient foam cutter power supply function
Specs:
Input Voltage: 10 ~ 18V DC
Charge Current: 0.05 ~ 10A
Discharge Current: 0.05 ~ 7A
Maximum Charge Capacity: 250W
Maximum Discharge Capacity: 20W
Current Drain For Balancing LiPoly: 300mAh/cell
Lithium (Li-poly/LiIo/LiFe) Cell Count: 1 ~ 6 series
NiCd/NiMH Cell Count: 1 ~ 17 series
Pb Battery Voltage: 2 ~ 24V
Battery Setup Memory: 10
Intelligent Temperature Control: Yes
Weight: 360g
Dimensions: 140 x 80 x 30mm
Includes:
1 x Turnigy Reaktor 250W charger
2 x Alligator Clips +/-
1 x XT60 / T connector charge lead
1 x JST / Futaba Charge Lead
3) FR632 Diversity 5.8GHz 32Ch Auto Scan LCD A/V Receiver http://www.hobbyking.com/hobbyking/stor ... duct=72733
As FPV becomes more popular manufactures have been meeting the demands for FPV users vs just rebranded security equipment, the FR632 is just one of those products truly built for FPV in mind. With built in 2ch diversity reception, Auto scan, 32Ch on 5.8GHz, a full LCD display that shows band/channel and frequency. A wide input voltage range and full shielded metal case to help receiver sensitivity.
Features:
• Auto channel scan and lock on
• True 5.8GHz 32CH diversity system with indicator
• Wide voltage input range
• Diversity and A B A/V
• Dual buffered A/V outputs
• Back light LCD
Specs:
Input working voltage: 6~28V
Receiver: Two -90 dbm ISM 5.8GHz 32CH
Diversity: RSSI based with led indicator
Outputs: RF1,RF2,Diversity
Dimensions: 78x68x15mm
Antenna connections: SMA
Included:
FR632 receiver
Power and A/V cables
2 dipole antennas
*For best range and video link stability we recommend using circular-polarized, Patch or Helical Antenna Set (SMA) available below in the accessory’s tab
Paskutinį kartą redagavo AlbertasA 11 Bal 2016 22:02. Iš viso redaguota 5 kartus.
 Pranešimo tema: Re: Fatshark 700TVL, TGY-i10 10ch 2.4GHz, Reaktor 250W Charg
StandartinėParašytas: 18 Vas 2016 20:47
Pranešimai: 6
Atnaujinta: Quanum DIY FPV Goggle V2 w/5 inch LCD Monitor (Kit)
 Pranešimo tema: Re: Fatshark 700TVL, TGY-i10, Reaktor 250W, FR632, Goggle V2
StandartinėParašytas: 02 Kov 2016 18:20
Pranešimai: 6
Pridėta: FR632 Diversity 5.8GHz 32Ch Auto Scan LCD A/V Receiver
 Pranešimo tema: Re: Fatshark 700TVL, TGY-i10, Reaktor 250W, FR632 Diversity
StandartinėParašytas: 04 Bal 2016 16:40
Pranešimai: 6
Quanum DIY FPV Goggle V2 - parduota
StandartinėParašytas: 11 Bal 2016 22:03
Pranešimai: 6
Išimtas Turnigy TGY-i10
