Dabar yra 18 Lie 2026 18:53
 Pranešimo tema: siustuvas Futaba 9cap super+ r146ip ir r137f imtuvai+ kvarc
StandartinėParašytas: 03 Sau 2008 09:59
Užsiregistravo: 11 Bir 2005 19:52
Pranešimai: 239
Miestas: Klaipeda
Puikaus stovio be ibrezimu gerai veikiantis 9 kanalu aparatas
Futaba 35MHz iustuvas 9cap super mode2 (galima perprogramuoti mode1)
Futaba 35MHz ppm 7kanalu imtuvas r137f http://www.rcsuperstore.co.uk/store/cus ... =22&page=1
Futaba 35MHz pcm lengvas 6kanalu imtuvas r146rhttp://www.rcuniverse.com/product_ ... ver_id=125
Futaba 35MHz kvarcai
kaina 890Lt
General Specs:
- Trainer Mode: Both
- Mode Select: No
- 8 Models
- Model Copy
Controls and Trim:
- DigitalTrim
- Trim Reset
- Trim Memory
- Sub Trim
- Trim Step Adj.
- 9 Channel Servo Reverse
- 2 Slide Controls
Special Functions:
- 7 Mixes
- End Point Adj.
- Dual Rates
- Exponential
- ATL
- Assignable Switches
- Assignable Channels
- Engine Start
Display Warning:
- LCD Display
- Low Battery Warning
- Timer
Applications:
- All Purpose
- Competition Airplanes
- Competition Helicopter
- Competition Sailplane
- Sport
Acrobatic Functions
- Aileron Differential
- Aileron to Rudder Mixing
- Air Brake Control
- Elevator to Flap Mixing
- Elevon Function
- Flap Travel
- Flapperon Function
- Snap Roll Switch
- Throttle Delay
- V-Tail Function
Helicopter Functions
- Governor Program
- Gyro Program
- Hover Pitch
- Hover Throttle
- Idle Up
- Offsets
- Pitch Curve
- Revo Mix
- Throttle Curve
Sailplane Functions
- Aileron to Flap Mixing
- Butterfly Mixing
- Flap Travel
- Speed Presets
- Start Presets
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
StandartinėParašytas: 08 Sau 2008 16:16
Pranešimai: 239
Miestas: Klaipeda
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
