Dabar yra 30 Rgs 2026 06:35
 Pranešimo tema: Parduodu variklius multikopteriui
StandartinėParašytas: 29 Rgs 2014 19:15
Užsiregistravo: 06 Geg 2013 19:35
Pranešimai: 1
Parduodu:
6 vnt. - Robbe ROXXY 2827-35
Technical Data:
Lithium cell count: 2-4
Load current: 6-9 A
Maximum load current. (60 sec): 10 A
No-load speed: 760 rpm / V
Recommended Propeller Size: 10x4.5 .. 12x4.5
Machanical power: 110 W
Thrust max.: 820 g
Wire length: 52 cm
Total weight (with / without cable): approx 69g/54g
Dimensions: 28,8 x 29 mm
Shaft diameter: 3.17 mm
2 vnt. - MK2832/35
Technical Data
Lithium cell count: 4
Load current: 6-9 A
Thrust max.: 820 g
Wire length: 52 cm
Total weight (with / without cable): approx 54g/68g
Dimensions: 28 x 32 mm
https://imageshack.com/i/p9Owjnkmj
https://imageshack.com/i/pb1YVP4sj
https://imageshack.com/i/iqzGPHHAj
https://imageshack.com/i/iqG34OOsj
https://imageshack.com/i/kppCRIMqj
https://imageshack.com/i/f0R4kTPoj
Abu tipų varikliai turi propelerių adapterius:. Šie varikliai stovejo ant mano MK Oktocopterio, ir tampe mano Canona 1,5 kg.
Visi klausimai į PM
Kaina: 8vnt.x80Lt=550Lt
