Dabar yra 30 Rgs 2026 12:21
 Pranešimo tema: TURNIGY 10amp Speed Controller su bec
StandartinėParašytas: 23 Rgs 2014 18:10
Užsiregistravo: 15 Bal 2012 18:55
Pranešimai: 195
https://www.hobbyking.com/hobbyking/sto ... oduct=4204
Plush 10A Brushless Speed Controller
The Plush series of ESC are a very good quality controller with a broad range of programming features and smooth throttle response compared to other BESCs in the same price range.
These escs have linear throttle curve and can handle 10A continuously.
Cont Current: 10A
Burst Current: 12A
BEC Mode: Linear
BEC : 5v / 2A
Lipo Cells: 2-4
NiMH : 5-12
Weight: 9g
User Programmable, both via controller and optional programming card. The programming card is an excellent item as it instantly tells the user the current settings and with a few simple clicks of the buttons, the user can change the settings and have graphical reassurance of those changes.
The programming card is an excellent item and simple to use! Much better than Jeti or similar programming cards.
PRODUCT ID: TR_P10A
Yra 3 vnt. Net neispakuoti, nauji.
10$ uz vnt.
Veiksmas Kaune, pagal galimybes galima ir i kitus miestus.
867146250
Vartotojai naršantys šį forumą: Registruotų vartotojų nėra ir 14 svečių
