Dabar yra 05 Rgs 2026 07:31
KURIS DALYKAS LABIAUSIAI DOMINA NORS IR NEPERKANT?
MONSTRAS 29%  29%  [ 5 ]
TRUGGIS 18%  18%  [ 3 ]
DUCTED FANAS 18%  18%  [ 3 ]
KROVIKLIS 0%  0%  [ 0 ]
PROGRAMATORIUS 0%  0%  [ 0 ]
AMORTIKAI 12%  12%  [ 2 ]
RATAI 0%  0%  [ 0 ]
CRAWLERIO DALYS 18%  18%  [ 3 ]
KITI NIEKUČIAI 6%  6%  [ 1 ]
Viso balsų : 17
 Pranešimo tema: ONROAD MONSTRAS 1/10; CASTER F18; RATAI; DUCTED FANAS IR TT
StandartinėParašytas: 02 Geg 2014 14:49
Užsiregistravo: 06 Kov 2011 01:08
Pranešimai: 12
Miestas: Panevėžys
1/10 MONSTER TRUCK. PIRKTAS IŠ CENURYUK.COM PUSLAPIO. PERDARYTAS NAUDOTI 1/8 MODELIŲ RATUS. KOKYBIŠKAI PAGAMINTAS MAŽAI NAUDOTAS APARATAS. RADIJA PROGRAMUOJAMA HK300 SU LIČIO BATERIJA. NUOTRAUKOJE GALBŪT NESIMATO GALINGA IR GREITA BLUEBIRD SERVA SU PAPILDOMU MAITINIMU, TYPHOON 500 OUTRUNNERIS, 160A TURNIGY ESC IR 4,5Ah 130C nano-TECH AKUMAS. TAIP PAT PRIDEDU AŠIS IR ŠEŠIAKAMPIUS 1/10 RATAMS BEI 1X 21T NAUJĄ PINJONĄ BEI NAUDOTĄ IR NENAUDOTĄ SPURĄ. VISKAS KAS REIKIA SUTEPTA IR HERMETIZUOTA TAD DĖL BALŲ NETURĖTŲ BŪTI BĖDŲ. NAUDOJANT 4S AKUMULIATORIŲ IR OFROAD RATUS TAMPA GAN PIKTU ŽVĖRIUKU - PIESTOMOBILIU (rock) WATMETRAS RODO IKI 1,3KW IR MOTORAS TIK SILTAS
SUDĖJAU BEVEIK VISKĄ (ONROAD PADANGŲ NEĮSKAIČIAVAU, AŠIŲ, PINJONŲ IR SPURŲ TAIP PAT) TAI IŠĖJO JOG MAN VISKAS SUKAINAVO 1135.35Lt VISKĄ PIRKAU ANGLIJOJ TAI MUITO SUSIMOKET NETEKO. LIETUVOJ KIEK KAŽKĄ DIDESNIO PIRKAU TIEK MOKĖJAU. TAIGI...
MANAU SĄŽININGA KAINA ATMETUS BEVERČIUS NIKELĮ, BRUSHEDA, IR TT BEI SUSKAIČIAVUS NUSIDĖVEJIMĄ PER 6 PRAVAŽIAVIMUS 600Lt.
CASTER F18 STADIUM TRUGGY. PAGYVENĘS BET DAR NIEKAS SMARIKIAI NEISKLERO. GUOLIAI TVARKINGI. RADIJA STANDARTINE 2,4GHz SU LICIO AKUMU. KOMPLEKTACIJOJ HK939MG SERVA, 3600KV MOTORAS, LEKTUVINIS ESC, ISOPERUOTAS 90C 2S 2,2Ah nano-TECH AKUMAS (BUVO 3S) IR "RPM" MINKSTI TOWERIAI. IMETU SUVAZINETAS PADANGAS KAI NORISI PADRIFTUOT, AMORTIKŲ REGULIAVIMĄ IR 55T SPURĄ (BERODS ĮDĖTAS 45T). PINJONĄ PAVEŽA NEKAISDAMAS IR DIDESNĮ NEI YRA. SENIAI BENAUDOJAU TAI NEBELIEČIU BET REIK PASIVERŽTI DIFUS IR PINJONA. 180Lt
Paskutinį kartą redagavo gyrtaz 07 Geg 2014 18:12. Iš viso redaguota 8 kartus.
 Pranešimo tema: Re: onroad monstras 1/10; caster f18; ir keletas gerybiu.
StandartinėParašytas: 03 Geg 2014 18:52
Pranešimai: 1663
Dar mesuskaiciavai?.
Noreciau pasiulyti kaina bet ne aukciono skilti
 Pranešimo tema: ONROAD MONSTRAS 1/10; CASTER F18; IR KITOS GĖRYBĖS
StandartinėParašytas: 07 Geg 2014 11:30
Pranešimai: 12
Miestas: Panevėžys
(KAŽKADA TURĖJO BŪTI ROCK CRAWLERIS)
SKELBIMĄ DAR PILDYSIU.
