Dabar yra 16 Rgs 2026 04:51
 Pranešimo tema: El. Variklis, Servai, ESC
StandartinėParašytas: 12 Bal 2014 10:32
Pranešimai: 330
nutariau parduoti modelius, kuriem niekaip neatrandu laiko. Geriau jau bus pas gerus zmones naudojami, nei pas mane dulkes ant lentynos.
Servos HXT 6.9kg / 39.2g / .16sec Twin bearing servo
Dimentions: 40x20x38mm
Weight: 39g
Speed: .16sec/60Deg
Stall Torque: 6.5kg
Dead Bandwidth: 4us
Voltage: 4.8~6v
Turiu 5 naujas po 5 Eu.
Naujas Variklis Turnigy 4258 Brushless Motor 400kv
Dimension: 52mm x 43mm, 76mm(with shaft)
Weight: 261g (kv400) (not including connectors)
Diameter of shaft: 5mm
Length of front shaft: 19.4mm
Lamination thickness: .2mm
Magnet type: 45SH
Max performance
Voltage: 4S
Max current: 50~55A
Prop: 12x6~13x4
Thrust: 2400~2900g
For 2500-3000g 3D model airplane.
Kaina 30 Eu.
Naudotas ESC ATHENA-18
Up to 18 amps continuous current with proper airflow
Dual Battery Eliminator Circuit (BEC) provides 2.0 amp (8v)stable, continuous power for your reciever and servos
Handles high-voltage applications up to 17V maximum with 4-cell LiPo batteries
Dynamic braking ensures that folding props fold properly
High-Temperature protection circuit
LiPo/Li-Ion battery low voltage auto protection design. Power will be cut off at 60% of the initial voltage
Easy Programming on brake function
The ESC will test the motor and set the timing automatically
Motor Auto cut-off with reset
Kaina 10 Eu.
Veiksmas Kaune, taciau kai ka galiu siusti per Pasta ar Kautros autobusu siuntas.
Tel. 868625477
Hpi Baja 5B, Hpi Savage 25
Paskutinį kartą redagavo Daktaras 04 Kov 2015 23:06. Iš viso redaguota 3 kartus.
 Pranešimo tema: Re: Savage Nitro, Variklis, Servai, ESC
StandartinėParašytas: 19 Bal 2014 11:04
Pranešimai: 330
Savage 600
StandartinėParašytas: 11 Sau 2015 17:49
Pranešimai: 330
Visdar parduodu
 Pranešimo tema: Re: Ikranas, Savage Nitro, El. Variklis, Servai, ESC
StandartinėParašytas: 24 Vas 2015 21:37
Pranešimai: 330
Prideta prekiu, pakoreguotos kainos.
StandartinėParašytas: 26 Vas 2015 15:12
Pranešimai: 330
Savage rezervuotas iki 02-27.
 Pranešimo tema: Re: Ikranas, El. Variklis, Servai, ESC
StandartinėParašytas: 02 Kov 2015 20:10
Pranešimai: 330
Išimti parduoti daiktai.
 Pranešimo tema: Re: El. Variklis, Servai, ESC
StandartinėParašytas: 04 Kov 2015 23:06
Pranešimai: 330
Ikranas parduotas.
