Dabar yra 10 Rgs 2026 12:44
 Pranešimo tema: HobbyKing 350w 25A Power Supply !!!!!!!(100v~120v)!!!!!!!
StandartinėParašytas: 29 Kov 2014 21:19
Užsiregistravo: 26 Lap 2009 19:45
Pranešimai: 166
Parduodamas naujas, supakuotas HobbyKing 350w 25A Power Supply (100v~120v) . Gal kam reikes...
Show the HobbyKing colors with pride at your local field with the HobbyKing 350W 25A power Supply. Light weight and compact, this power supply features dual 13.8v outputs and is suitable for 2 chargers up to 350w (Combined). The HobbyKing 350w Power Supply also features over current and over temperature protection and warning LEDs.
Specs:
Input Voltage: 100~120V AC
Output Voltage: 13.8v DC
Output Amps: 25A
Output Watts: 350W
Temperature Cutoff: <100deg C
Cooling: Single Fan
Dimensions 165.5 x 111 x 50.5mm
Weight: 710g
Uz ji noreciau astuonesdesimt penkių litų. . Priimu paypal. Mokescius mokate jus. Prasau, nerasykite zinuciu, kad prasau per daug. Patikekite manimi, pigiau tokio dalyko nerasite :)
Siunciu i kitus miestus. Siuntimas nebrangus. Registruotas, pirmenybinis - 7 lt
Telefono nr. 865101001
Atrasau i PM.
Facebook - Teodoras Bliuvas
Galimos derybos
