Dabar yra 28 Kov 2026 09:19
 Pranešimo tema: parduodu skubiai dvd modelevimui ir ne tik
StandartinėParašytas: 20 Vas 2014 22:33
Užsiregistravo: 03 Lap 2011 19:47
Pranešimai: 15
uz ji noretciau 200lt miestas kaunas siuntciu i visus miestus nr 864130974 rasykite i tel
Highlights:
Two crystal-clear 7" (18cm) LCD monitors with anti-reflective coating and wide viewing angle.
Display-integrated DVD player with excellent format compatibility, allowing playback of DVD, CD, JPEG and MPEG4
Multimedia USB and SD input for playback of MPEG4 video and JPEG images.
Ability to connect with external audio sources.
Can be powered via an AC adaptor or 12V cigarette lighter.
Contains straps for mounting the monitors on headrests.
Features:
Connections: Main Monitor: 1 x USB, 1 x SD input, 1 x 3.5mm headphone jack output, 1 x 3.5 mm mini-jack AV input and output.
Additional Monitor: 1 x 3.5mm headphone jack output, 1 x 3.5mm mini-jack AV input.
Playable formats: DVD, CD, and MPEG4 compatible DVD-R, DVD + R, DVD-RW, DVD + RW, CD-R, CD-RW, JPEG
Easy to use with on-screen display, console or remote control
Supported picture formats: 16:9, 4:3
Built-in speaker
Zoom function
Slow motion function
Repeat function
AB-sequence repeat
Programming function
Angle function
Slide show function
JPEG image rotation
Mute function
Parental control
Numerous picture and sound settings
Supported image systems: PAL, NTSC
Included:
1 x Main Monitor
1 x Additional Monitor
1 x Remote control
1 x Mains adaptor
1 x 12V cigarette lighter adaptor
1 x Travel bag
1 x 3.5mm jack-RCA-AV cable
1 x 3.5mm jack cables
2 x Headphones
Strap for headrest mounting
English language manual (other languages including: German)
Please note this item requires an EU to UK power adaptor. We will include one free of charge in your delivery.
Dimensions:
Main monitor: 7.9 x 1.8 x 5.9" (20 x 4.5 x 15cm)
Additional monitor: 7.9 x 0.8 x 5.9" (20 x 2 x 15cm)
Main monitor weight: 650g
Secondary monitor weight: 330g
$_72.JPG [ 27.63 KiB | Peržiūrėta 1229 kartus(ų) ]
