Dabar yra 16 Spa 2026 17:24
 Pranešimo tema: 8ch FM rx, Schottelantrieb II
StandartinėParašytas: 25 Lap 2013 15:46
Užsiregistravo: 06 Bir 2012 21:11
Pranešimai: 160
Miestas: Šiauliai
Parduodu vokišką 35MHz 8 kanalų imtuvą
The Schulze Alpha -835s and 835w receivers are ultra compact 8 channel , lightweight FM-PPM units designed specifically for the electric flight market, but can be utilised in other disciplines. Their micro-processor controlled signal analysis stage suppresses interference and noise on the selected channel to a unique extent, in a similar way to PCM. This technique allows the receiver to detect interference, suppress it, and replace the invalid values (similar to PCM). The signals passed to the servos always lie within normal limits, and the servos are usually able to process them without problem. The receivers also have installed a reception quality indicator LED (glitch counter) which can be inspected after flight. Futaba single conversion crystals can be used in these receivers. The two receiver differ in their servo output pin configuration, see picture. 835s weight (less crystal) 13 grams size 45 x 21 x 13mm
Kaina 50Lt.
Bei parduodamas Graupner Schottelantrieb II
http://www.graupner.de/de/products/b5d0 ... oduct.aspx
Kaina 70Lt.
Šiauliai, tel. 868918512, Arnoldas
Vartotojai naršantys šį forumą: Sargybinis ir 12 svečių
