Dabar yra 13 Spa 2026 14:09
 Pranešimo tema: Multiwii and Megapirate AIO Flight Controller + Hard Case
StandartinėParašytas: 30 Rgs 2013 09:50
Užsiregistravo: 30 Rgs 2013 09:42
Pranešimai: 4
Parduodu kontroleri su case'u:
Multiwii and Megapirate AIO Flight Controller w/FTDI (ATmega 2560) V2.0
Hard Case for MultiWii and MegaPirate AIO Flight Controller
Veikia gerai, naudotas iki 10 kartu, jokiu crashu neturejes.
Features:
• Supported MegaPirateNG and MultiWii firmware
• Up to 8-axis motor output
• 8 input channels for standard receiver
• 4 serial ports for debug/Bluetooth Module/OSD/GPS/telemetry
• 2 servos output for PITCH and ROLL gimbal system
• 1 servo output to trigger a camera button
• 6 Analog output for extend device
• A I2C port for extend sensor or device
• Separate 3.3V and 5V LDO voltage regulator
• ATMega 2560 Microcontroller
• MPU6050 6 axis gyro/accel with Motion Processing Unit
• HMC5883L 3-axis digital magnetometer
• MS5611-01BA01 highprecision altimeter
• FT232RQ USB-UART chip and Micro USB receptacle
• On board logic level converter
Flight mode for Multiwii:
• One of the following basic modes
– Acro
– Level
– Alt Hold
- Heading Lock
• Optional mode
– HeadFree (CareFree)
– GPS Hold (Need GPS receiver)
– GPS Back to home position (Need GPS receiver)
Flight mode for MegaPirate:
• Acro
• Alt Hold
• Loiter (uses GPS)
• Guided (uses GPS)
• Position (uses GPS)
• Circle (uses GPS)
• RTL (uses GPS)
• Auto(uses GPS)
• Follow Me(uses GPS)
Sizes:
Dimension: 50mmX50mm
Height: 11.6mm
Fixing hole spacing: 45mm
Hole diameter: 3mm
Weight: 14.2g
Includes:
1 x AIO PRO FC
3 x 3Pin to 1Pinx3 cable 100mm
1 x 3Pin to 3Pin cable 100mm
1 x Molex 1.25mm 4Pin cable 100mm
1 x Molex 1.25mm 6Pin cable 100mm
1 x Molex 1.25mm 8Pin cable 100mm
110Lt
Vilnius
8 616 01777
