Dabar yra 22 Rgp 2026 08:17
 Pranešimo tema: RTR, ESC, Variklis, Shocks, Jungtys, Li-Po, Servos
StandartinėParašytas: 30 Bir 2013 01:15
Užsiregistravo: 02 Lie 2009 17:23
Pranešimai: 39
Sveiki, išparduodu stalčių turinį:
(Kadangi visi daiktai yra VISIŠKAI NAUJI tad atiduodu panašiom kainom kaip ir pirkta)
Micro USB Female 5LT
T formos jungtis (female) 3LT
Hobbywing Programavimo korta (man neveikė, nes matyt ESC ne tas) 10LT
Du Li-Po Akumai 3S (11.1), 20C , 1800mah. Nenaudoti. Įkrauti iki "Storange mode". 50LT
Pinion 19dantų 12LT (1:10 modeliui)
Servos Traukės su varžtukais n-stuff 10 LT
Caster 10B Shock Tower'iai (Plastikiniai, nė karto nenaudoti), 15LT
Priekinis šakių tvirtinimas (nenaudotas) 5LT
Sankabos, Ball Diff'o spyruoklė (neužsikirtus, čiki piki) 5LT
Amortizatoriai 100mm, Aliuminiai, Reguliuojami. Poros kaina 25LT
Motoriukas. 40LT
Outrunner
Model No.: A3530-10
KV: 1400
Weight: 74g
Motor Dimensions: Ф35*30mm
Shaft Size: Ф4.0x49mm
Prop/ recom: 9x4.5/8x4
Battery: 2-4Li-Po
Idle Current: 1.2A
Load Current: 14.8A
Power(Watt): 430
ESC(A): 30A
Ri (Ω): 0.051
Pull (Approx): 580g
ESC Greičio Reguliatorius 45LT
60A
Constant current 60A Max 80A <10s
Size : 65 x 39 x 13mm
Weight : 61g
High Voltage Li-Poly 2-7 cells, Ni-MH 6-20 cells
Low resistant 0.0014 ohms
Dynamic braking
BEC : OPTO
Auto shut down when lose signal
Slow down at 3.0V per cell Lipo, Cut-off at 2.9V per cell Lipo 0.8V Nimh
User programming options
Battery Setting
Throttle Range
Brake Setting 4 options
Direction and Cutoff Type
Timing Mode Setting: 1º /7º /15º/30º
PWM Setting: 8K/16K
Important Note: this ESC is Opto, without BEC supplying power to your Receiver, you need extra power source for your receiver. You can use a UBEC, a voltage regulator, or extra batteries as the power source for your receiver. If you hear the music tone repeat again and again for more than 3 times, you may need to check your power source to the receiver.
Analoginė Serva 20LT
Sukimo momentas: 1kg/cm
Voltažas: 4.8-6V
CASTER 10B RTR
Visiškai paruoštas, Pridedu ir pakrovėją (aukščiau), reikėtų tik maitblokio.
Na ir galbūt kas nors susidomės modeliuku. Įdėta daug laiko ir meilės :)
950LT
450W sensorinis variklis, Sensorinis ESC, Turnigy Nano-tech 4.85Ah (įsikrauna beveik viskas, nors tiesą sakant kol kas taip ir neteko pilnai iškraut, nes laiko virš 20min). Niekas nelūžę, Foto purvina, bet jei atsiras pirkėjas, viskas bus išvalyta. Greičio nematavau, bet pakankamai, jog neina suvaldyt. Siųstuvas programuojamas, su baterijom (kraunamos).
Dar pridėsiu amortizatorių tepalo pilną buteliuką. (Manual'as, dėžė viskas irgi yra)
___________________________________________________________________________
Brėžiniai su Autocad, Modeliavimas su 3DS Max
Brėžiniai grafinio dizaino programomis (Autocad ir panašiomis), maketavimas, 3d modeliavimas,
Klasikinė braižyba.
Skype: nelysk4
Kaunas
865898649
