Dabar yra 23 Rgp 2026 01:27
 Pranešimo tema: Thunder Tiger Titan X50 uz ypatinga kaina, nauji!
StandartinėParašytas: 11 Bir 2013 15:42
Užsiregistravo: 11 Bir 2013 15:32
Pranešimai: 1
Visiskas naujas RC sraigtasparnis, sudedamas pirkejo. Karbonines detales, auksciausia klase.
Isskirtinis daiktas, puiki dovana kiekvienam RC modeliu myletojui. Stulbinamai tikslus valdymas (mirties kilpos ir t.t.) Galingas motoras.
Aprasymas angliskai:
Thunder Tiger Titan X50 Electric Torque Tube Flybarless Kit
Get ready to handle this awesome machine that you would have never seen before! Titan X50 Electric is inherited from the Nitro version but 100% exclusive design is promised for a electric power, which is acceptable between 8~12S LiPo so that its performance is enhanced to a new high peak.
The TITAN X50E is supplied as a KIT and requires assembly, Motor, ESC, Battery & Electronics.
Key Features
Lightweight, rigid one-piece metal main rotor hub
Enlarged titanium rod and ball linkage for rigidity and extreme pitch response
Longer metal control arms for high control resolution
Top mounted motor for better CG and efficient heat dissipation
Motor mount for both M4x30mm and M3x25/ 30mm bolt position
Accepts wide range of motor sizes. Maximum diameter 52 mm
Enlarged 135T vented main gear (Mod 0.8)
Adjustable gear ratio to accommodate different motor KV.
(15T pinion included for 6 mm motor shaft)
One-piece carbon frame with 30 mm slim profile
Extended electronics tray for installation versatility.
All metal control arms assembly eliminate the need for upgrades
120-degree CCPM control system, option 140-degree convertibility
Integrated reinforced ribs and control arms base around the motor for strength
Adjustable motor mount and pinion bearing block
Enlarged room for LiPo battery pack, applicable to a 8~12-cell pack
High-quality colour shifting pre-printed canopy
Lightweight and durable landing skid set
Includes 600mm Carbon Main Blades
Specifications
Length:1200mm
Height: 400mm
Width: 200mm
Main Blade Length: 600mm
Main Rotor Dia.: 1,345mm
Tail Blade Length: 95mm
Tail Rotor Dia.: 260mm
MIESTAS: KLAIPEDA (siunciu i visus Lietuvos miestus)
Telefonas: +37065400553
Kaina 1100Lt
akcija-thunder-tiger-titan-x50-tik-pas-mus-1199lt-260080223 (1).jpg [ 44.01 KiB | Peržiūrėta 1021 kartus(ų) ]
