Dabar yra 03 Lie 2026 01:05
 Pranešimo tema: Parduodu naujas servas
StandartinėParašytas: 18 Vas 2013 07:49
Užsiregistravo: 23 Spa 2012 14:31
Pranešimai: 47
MG996R Metaliniu spuru serva. 50lt. pristatymas Lietuvoje nemokamai.
Uploaded with
- Operating speed: 0.17sec / 60 degrees (4.8V no load)
- Operating speed: 0.14sec / 60 degrees (6.0V no load)
- Stall torque: 9.4 kg-cm at 4.8V
- Stall torque: 11 kg-cm at 6V
- Operation voltage: 4.8 - 7.2Volts
- Gear type: all metal gears
- Connector wire: 30cm
Dimensions:5.4 cm x 4.3 cm x 2 cm
Weight:76 g
