Dabar yra 15 Spa 2026 02:04
 Pranešimo tema: E-FLY ETC61 2,4Ghz valdymas
StandartinėParašytas: 08 Sau 2013 13:33
Užsiregistravo: 08 Sau 2013 11:49
Pranešimai: 3
Mazai naudota aukstos kokybes
E-FLY ETC61 2.4Ghz valdymo sistema su 6 kanalų imtuvu.
siustuvas,imtuvas,kabeliukas simuliatoriui, softas
Characteristics:
- Dual Rate and preset mixers
- Using synthesis technology, the microprocessor automatically sets the frequency, so no need for crystals. No interference.
- With the new 2.4 GHz technology, the servos offer a faster response, greater accuracy and does not shake
- 2.4 GHz sysmtems using GFSK modulation, so the power amplifier works only when transmitting data, this way obtaining a higher emission time for the same battery
- Being a 2.4 GHz system the transmitter and receiver antennas are very short
Specifications:
Dimensions: 180 x 190 x 70 mm
Weight: 824 g
Modulation: 2.4 GHz
Channel number: 6
Range: >800 m at ground and >1200 m in air
Antenna length: 150 mm
Kit contents:
1x Transmitter E-FLY 100C 6 channel 2.4 GHz
1x Receiver 6 channel 2.4 GHz
1x Instruction manual
Functions:
This transmitter has 4 preset models:
A (airplane)
- The ranges of CH1, CH2 and CH4 of servos can be adjusted by Tiny mix1 in order to adjust for different aerobatics
- The function of CH1, CH2, CH4 small angle and large angle can be changed by switch 3
- The mixture function of ch1 and ch6 can be achieved by switch 2
- There is a isolated channel for landing gear and that function can be achieved by switch 1
- Reverse switch for CH1, CH2, CH3, CH4 and CH6
- Lock and unlock function. When every data is settled, the situation can be saved with lock function and every change will be not accepted
- Alarm for low voltage: when voltage of battery is under 8.5 V, the red LED will flash and when under 7.5 V, LCD will close
V (V-Tail mode)
- The mixture function of ch1 and ch6 can be achieved by switch 1
- The range of servo for CH4 can be changed by tiny mix2
- The function of CH1, CH2, CH4 small angel and large angle can be changed by switch 3
- There are two isolated switch channel CH5 and CH6. And collapsable landing gear as well as photo-taking can be achieved by switch channel 1 and 2
- Lock and unlock function. When every data is settled ,the situation can be saved with lock function and every change will be not accepted
H (helicopter mode H1)
- PIT and PLT can be adjusted by tiny mix 1 and 2
- There is a switch for the function of Gyro and can be switched between normal mode and head lock mode by switch 1
- The switch 2 is settled for 3D diverted flight
C (CCPM helicopter)
- The mixture function of CH1, CH2, CH3 and CH6 can by achieved for CCPM helicopter. PIT and PLT can be adjusted by tiny mix 1 and 2
Items from pictures 2 and 3:
A: Antenna
B: LCD
- to indicate the battery voltage of transmitter
- to show the situation of channels whether it is reversed
- to show the flying time
- to indicate flying mode
C: Tiny Mix 1
- Under Mode A, it is for CH1, CH2, CH4 and CH6 and that can change the turning range of servos
- Under Mode V, it is for CH1 and CH2
- Under Mode H, it is for PIT adjustment
- Under Mode C, it is for PIT adjustment
D: Tiny Mix 2
- Under Mode A, it is for CH6
- Under Mode V, it is for CH4
E: Switch 1
- this switch is for Ch5 that can be used for aerial camera, collapsible landing gear and shift between gyro mode and gain, etc
F: Switch 2
- Under Mode V, it is can be used for aerial camera and collapsible landing gear
- Under Model H, it is the switch for diverted flight
- Under Mode C, it is the switch for diverted flight
G: Flying Mode Switch
- When the lock switch is on ADJUST, transmitter will be indicated as Mode A, and it is can be adjusted to A/V/H/C Flying Mode
H: LED Indicator for Power
I: Red LED Indicator for low Voltage: When battery is under 8.5 V, the LED will have a flash alarm; the LCD will cut off when voltage is under 7.6 V
Note: When red LED flashes or nothing shows on LCD, pls change the battery in order to avoid flying out of control
J: Joystick
- If the transmitter is Model 1, CH1is for aileron and CH3 for throttle
- If the transmitter is Model 2, CH1 is for aileron and CH2 for Rudder
K: Joystick
- If the transmitter is Model 1, CH2 is for elevator and CH4 for rudder
- If the transmitter is Model 2, CH3 is for throttle and CH4 for rudder
L: Tiny Mix for Channels
- If the transmitter is Mode 1, it is for CH3
- If the transmitter is Mode 2, it is for CH1
M: Tiny Mix for Channels
- If the transmitter is Mode 1, it is for CH1
- If the transmitter is Mode 2, it is for CH3
N: Tiny mix For Aileron
O: Tiny mix for rudder
P: Flying Ring
Q: Switch for Power
R: Lock Switch
- When the lock switch is on LOCK position, all the other shift is under lock; when the lock switch is on ADJUST position, and all can be adjusted
S: CH1, CH2, CH3, CH4, CH6 Reversed Switch
- For changing the turning of servo, up for reversed and down for normal
T: Steel Handle
U: TX Crystal
V: Battery bay for transmitter
W: Plug for Simulator
X: Rechargeable plug(Note: Only 9.6 V NiMH battery pack can be recharged)
Y: Switch 3
Kaina: 240 Lt
